Question about Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive
HDD wont get formatted
Hi All, my HDD was a seagate 40G, I have a problem of formatting the hard disk, I tried using the set-up disk to format but can't, it was in NTFS but I want to use the FAT disk format to use in my Windows 2000 OS, please help...thanks so much!
    Scholar:
  • 104 Answers
Hi, maybe the easiest way for you to format this drive would be if you could attach it as a secondary drive in a pc that is currently working and then try formatting it in the desired format from within windows. Windows will recognize a drive it only needs to format it in order to access it for data storage. You may need to change the jumper setting to slave on the HDD before you plug it in.
If you need any help with this just let me know.
SeaJade
Posted on Jan 27, 2008
Hi, i have a Seagate Expansion 1 TB USB 2.0 Desktop External Hard Drive and i want to backup my macintosh by using disk utility. However it seems like as i plug the hard drive in, i cannot put anything...
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in Mac OSX Journeled Format.
6. Click Apply.
7. Done.
P.S. : It will erase everything from your HDD so remember to backup all data before doing this.
Hope it Helps..!!
Jul 13, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
Unable to formate seagate free agent go 320 g
Please check if you are getting error whenever you format it...or you might want to try other format options...http://www.mahalo.com/how-to-format-a-hard-drive/ and http://www.hdd-tool.com/hdd-tool/hdd-format-tools.htm unless if it is not being recognized by your computer then surely it wont let you format it...
Jul 06, 2011 | Computers & Internet
Error occured while formating my 40g seagate hard disk..
your hard disk might have got damaged.
try installing on other hard disk and see the difference.
Nov 13, 2010 | Seagate HDD 40GB 7200RPM ATA100 2MB...
I cannot use format my free agent go. It shows that I/O device is error and sometimes show that the parameter is incorrect
u have to connect your hdd on anther usb port and try to format if its not work then change the cable of hdd then try to format your hdd
Nov 13, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hard disk prolem'
Probablel corrupt partition. Please advise which OS you are using. In windows you can access the drive from disk managerment from where you can re-partition and format it. Keep me posted
Jul 26, 2009 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
CHANGED HDD FORMAT
The best thing you can do now will be to obtain a windows Startup disk and use fdisk utility to format.. If you are using a seagate HDD then you can also try seagate disk manager. Another option will be to boot from win XP CD and start the setup.. During the setup it will at some point it will provide you the options
1)format using NTFS
2)FOrmat using FAT
3)Format Using FAT32
From these choose format using FAT32. Thats all it will be formatted.. Afterwards you can use a tool like Partition Magic to resize and create more drives on the HDD.
Sai.
Mar 21, 2008 | Toshiba Satellite P105-S6104 Notebook
How to fix hard drive that's not appear in window but seen in bios
You can use a more sophisticated partitioning and formating software program such as GParted or Acronis Disk Editor. Both programs can create a bootable cdrom that will boot and allow you to delete create and format partitions.
gparted: http://gparted.sourceforge.net/
acronis: http://www.acronis.com/
good luck!
Brad Nelson
Mar 15, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Hard disk failure
Hi, assuming the hdd won't finish a format, it is possible that some sectors are damaged. If you still want to try and use the hdd even with these defects, you can try and partition the hdd. Guesstimate at what point the hdd stops responding and really guess where the defects end. With this info, partition the hdd into 3 with the middle containing the defective sectors. Format only the first and third partitions. For simplicity, Win98 might be easier to work with rather than XP. Hope this be of some help. Do post again and let us know how things turn up.
May 05, 2007 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive Logo
165 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
