Question about Eclipse CD7000 CD Player
Eject button will not eject cd
My eclipse cd7000 will not eject the cd. It just continues playing the cd. any ideas?
Mine was stuck in there for almost a year until I disconnected the battery (for other reasons) and when I reconnected it, the CD finally saw the light again.
Posted on Mar 29, 2008
6ya staff
SOURCE:
How do I have to restart my eclipse avn52d car audio cd drive after I changed my car battery ?
You must be inside the Eclipse in order to unlock the radio's security system.
Insert the key in the ignition. Turn it clockwise one notch so some of the car's controls turn on, but not the ignition.
Press the radio's "On" and "Screen/Text" buttons at the same time and hold both down until "SEC" appears on the radio's screen. After two seconds, the screen will change to read "DISC."
Press the "Open" button on the front of the radio. The front panel should open it.
Insert the Key CD into the CD slot. The message "SEC" appears. You should have received this CD when purchasing the car. If you don't have this CD, contact your Eclipse retailer for an extra one.
Eject the Key CD by pressing the "Eject" button and close the front panel of the CD player.
Jan 27, 2018 | Eclipse Car Audio & Video
Buttons not working on Sony icf-cd7000
Hello
Unplug the unit and replug it after 5 minutes or so. Then Hold Down the CLOCK/DATE until a short beep sounds. If this beep sound cannot be heard, be sure that the internal circuit has some trouble, and has to be repaired. Normally, any other button get strucked, there will be no response with other buttons. OK.
Nov 02, 2011 | Sony ICF-CD7000 CD/MP3 Clock Radio (Black)
I have an Eclipse CD7000 head unit. I touched the power lead (unfused) to the back of the deck. the deck will not power on anymore? Help?
It is possible that the shorting might have resulted in creating a damage within the set and it must be probed first with the power connected diectly , then the swithced power and tthe ground. now trace the power +12 to the main circuit after switched power is on.
If there is a line fuse you are lucky as much a fusible resisitor.
If there is power to mP then check for oscillations , the allied circuits.
If set powers up check the output IC,possible if the output has shorted the protecction canbe ON. so disconnect power to IC and check.
Sep 25, 2010 | Eclipse CD7000 CD Player
My eclipse cd3404 player is off and tells me to call 800SC502970 what do i do? happened after new car battery.
If you are the original owner, you should be having the CD which you played first. That CD acts as a key as an anti theft protection. However if do not have the CD then ring up eclpse and have your Serial Number ready at hand. They are the only ohes who can help you out to make a new key. This happens every time the battery is disconnected. So all the best............sodeep
Aug 03, 2009 | Eclipse CD7000 CD Player
Disk Eject Continuously
keep pressing the tray of CD. After some time time it will stop there
Jul 10, 2009 | Dell Studio 15 Laptop
Eclipse ucnv 884 not function
changing the lanuage from Japanese to english
Jul 02, 2009 | Eclipse (AVN7000) Car DVD Player
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
How to hook up sirius radio with cd7000
all you will need is the eclipse ecl- sc1 module and a subscription and you will be off and running with this deck
Sep 24, 2008 | Eclipse CD7000 CD Player
Won't eject cd or continue to run.
try holding down the eject button as soon as you turn the system on for more than 10 seconds. thats how you reset the cd drive. hope this helps. if not phone sony as its covered by a one year warranty as standard
Jan 07, 2008 | Sony Playstation 3 (PS3) Console
No output when I play a CD
what kind of vehicle do you have? i am going to guess your vehicle has a stock amp that it uses to power your speakers? you will have to hook up the remote wire for the amp to the wire that powers the amp in your vehicle (the stock amp) right now it seems like you have the "power antenna" wire hooked up to the stock amp in your vehicle.
Aug 24, 2007 | Eclipse CD7000 CD Player
Eclipse CD7000 CD Player Logo
178 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
