Question about Fuji FinePix A345 Digital Camera
Fuji a345 digital camera will only take video footage, not photos
Camera seems to be stuck in video mode, cannot change it to photos or even view the photos on it????
  • 667 Answers
The three position switch for play,camera,video has likely broken. The plastic switch on the outside has a small contact plate held to the back of the switch on the inside with one small screw. I do have a replacement on hand if you are interested.
Posted on Jan 27, 2008
Can I place a "Date
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Feb 09, 2011 | Fuji FinePix A345 Digital Camera
Finepix a345 will not switch on
Does it power up in playback mode? If you can view pictures try switching over to camera mode and see if the lense will extend. if not then your lens is possibly stuck. possible solution in "THE ONLY WAY I KNOW HOW..." In my tips n tricks section. Also is my email if you want some pictures of an A345 opened up. Cheers.
Apr 28, 2009 | Fuji FinePix A345 Digital Camera
I lost the cd to install the software installation in the computer - model Fuji FinePix A345 Digital Camera
With most recent computer systems, you don't really need the software that came from the camera manufacturer.
  • Connect the camera to the computer using the USB cable that was included.
  • Put the camera in the mode for viewing pictures already taken (not sure if necessary).
  • Turn on the camera.
  • At that point, the computer should recognize the device.  It may take a few moments to configure itself properly.
  • Then the computer should make the camera available just as if it were another disk drive (or flash drive).  You should be able to drag or copy photo files from the camera to the computer.  You will first need to navigate through the directory/folder structure of the camera -- the photos are not in the root directory.
Hope this helps.
Sep 20, 2008 | Fuji FinePix A345 Digital Camera
Fujifilm A345 Switch will not operate correctly; Will not switch between play, camera, and video
The only thing I've seen on this model and similar ones is the metal plate on the back side of the switch becomes loose. Beyond that, it sounds like a logic problem in the circuitry. It is probably not cost effective if that is the case.
Jun 13, 2008 | Fuji FinePix A345 Digital Camera
Stuck in video standby mode! help!
Lori, the switch above the display may be broken. does it still 'click' at each of the 3 settings? (play,video,camera)
Mar 18, 2008 | Fuji FinePix A345 Digital Camera
Webcam a345
You need the USB cable to connect the camera to your computer and in the setup menu, change your USB mode to PC
Feb 03, 2008 | Fuji FinePix A345 Digital Camera
The mode won't change
There are no repair option with a camera this old. Best bet is to but another
Aug 17, 2007 | Fuji FinePix A345 Digital Camera
Can't take pictures in picture mode
you are sure you are switching to Photo and not video? Check the manual carefully. This is a most unusual happening. If you absolutely certain that this is what happening. Get onto Fuji Tech Support team.
Jul 06, 2007 | Fuji FinePix A345 Digital Camera
Fuji finepixA340
I suppose you've already turned the dial? Yea, on my camera there's dial ontop to turn to select the display mode, and then I turn it to the "shoot" mode, its usually a camera icon.
May 23, 2007 | Fuji FinePix A345 Digital Camera
A345 stuck in movie mode
you need to open the camera caseing a small amount. As you put the case back make sure the switch is in the movie position so it will engage the switch inside on the circuit board. Looks like the switch has been knocked off the control inside.If you have been moveing the switch back and forward you may have broken it.
Dec 27, 2006 | Fuji FinePix A345 Digital Camera
Fuji FinePix A345 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
