Question about HP Pavilion a305w (DM181AR) PC Desktop
Monitor not coming on - Packard Bell Easynote R4650
Hi - the cat stood on the keyboard last night and turned the computer off! Now when I turn the power on, the computer starts whirring but the screen doesn't come on at all. Is there a keyboard shortcut or something to get it going again? Please help!
  • 2 more comments
  • si1604 Jan 26, 2008
    Thank you - all sorted now!
  • lowey121 Oct 06, 2008
    well mine wasnt the cat i used my laptop 3 days ago now nothing when i turn it on nothing is happening the fan spins everything sounds normal untill it starts beeping and the screen is black can anyone help me with this please
  • sambo-boroxx Feb 28, 2009
    my sister recently droped my laptop on the floor and ever since then the screen is just black but it still the power light comes on and it beeps and you can hear the fan loading? help me pleasee?
  • lowey121 May 11, 2010
    i have a packard bell laptop when i switch it on it beeps for 5 secs than does nothing doesent boot nothing than beeps again for 5 secs every 10secs can you help me please
    Novelist:
  • 123 Answers
It's a dreadful way to start a day - you press the power button on your computer and nothing happens. Do not fear because all may not be lost! Follow these simple steps to determine why your computer won't turn on.
Note: It is very important to troubleshoot any issue beginning with the most likely and easily testable problem so be sure to follow these steps in order.
Difficulty: Average
Time Required: Anywhere from 10 minutes to a few hours or more depending on why the computer won't turn on
Here's How:
As silly as it may sound, the number one reason why a computer won't turn on is because it wasn't turned on! Before starting a sometimes time consuming troubleshooting process, make sure you've turned on every power switch and power button associated with your computer:
Power button/switch on the front of the computer's case.
Power button/switch on the front and/or back of the monitor.
Power switch on the power supply on the back of the computer.
Power switch on the power strip or surge protector (if you have one).
Verify that the power supply voltage switch is correctly set. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on.
Check for loose computer and monitor power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
Perform a "lamp test" to verify power is being provided. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
A damaged power supply could be preventing the computer from being properly powered.
Do a quick test of the power supply by holding your hand behind the power supply fan located at the rear of the case. If the power supply is working, you should feel air from within the case blowing against your hand. If not, you may need to replace the power supply.
Tip: Is the power light on the front of the computer's case on? If you've turned the power switch on but the light is off, this is another good indication that the power supply is the cause of this issue.
Over time, internal components and the cables that connect them can wiggle loose which can often times result in a computer unable to power on. Try reseating the following and then try to power on the computer again:
Reseat the internal cables
Reseat the memory modules
Reseat the video card
Reseat other expansion cards
Reseating the CPU may also be necessary but should only be attempted if the reseating of all other components is not successful. This is due to the fact that this process is a little more involved and can run a small risk of damage to the CPU. This isn't a big concern if you're careful, so don't worry!
Check for causes of electrical shorts in the computer case. This is often the cause of the problem when the computer powers on for a second or two but then powers off completely.
Most monitors have a small light next to the power button that can change between various colors. If the screen is blank, this light is your main source of information about the monitor.
If this light is not on at all, double-check the power switch and connections (Steps 1, 2 and 3) and also make sure the monitor cable is securely plugged in to the video card port on the back of the computer case. If the light is still off, replace the monitor. If it comes back on, try starting your computer again - a loose or unplugged monitor cable may have been the issue all along.
An amber or yellow power light simply means that the monitor is not receiving any information from the computer. In and of itself, this doesn't tell us much.
On the other hand, if the light is amber or yellow, the computer power light is on, and the hard drive is active (making familiar sounds and the hard drive activity light on the computer case is blinking), the computer is probably starting normally but the video card is not sending information to the monitor. Replace the video card.
Beep codes (see Step 11) usually sound when a video card has malfunctioned but this is not always the case.
Is your computer making a beeping sound? Sometimes a computer will turn on just enough to play a series of beeps from the speakers.
These beep codes play in particular sequences and represent a specific problem that your computer is having. Troubleshoot the beep code to figure out what it's saying and then service the computer as necessary.
Tips:
Still can't get your computer to turn on? Let a community of computer support enthusiasts help out! Post the details of your problem in the Focus on PC Support Forums.
Posted on Jan 26, 2008
There is a dimmer screen that is accessible on this model and it looks like the screen is turned off but it is not. If you press the blue 'FN' button in the left lower corner and F11 together it should come back on. You sometimes have to do this twice as there seems to be a dim mode and completly off mode.
Posted on Jun 01, 2008
    Novelist:
  • 123 Answers
Difficulty: Average
Here's How:
Tips:
  • 2 more comments
  • Anonymous Jan 26, 2008
    It work for all note book and desktop
    i think it works.
    it will work
    it will surely work.
6ya staff
SOURCE:
Old Packard Bell Easynote R4650. Where is the CMOS battery?
Hi Brian.
not sure if this will help you out.
go to this youtube link might be of help to you.
Packard Bell Easynote R4650 cmos battery YouTube
Jul 04, 2018 | Packard Bell Computers & Internet
How i unlock my keyboard. lts packard bell easynote TE11 BZ
Hello
Does the whole keyboard not work or only some keys?
Try the following shut down the computer , disconnect the power cable and remove the battery from underneath then press power button for about 20 seconds then reconnect the battery and the mains power and switch on the laptop again.
Did you spill any liquid on the keyboard?
Jan 23, 2015 | Packard Bell Computers & Internet
Packard Bell Easynote SJ51 Problem!!!
I have _exactly_ the same problem, my Packard Bell SJ51 notebook is also 2 years old.
Sep 25, 2009 | HP Computers & Internet
Recovery
with HP its usually at boot startup, you can press one of the F keys to start it.
Jan 13, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Packard bell easynote r4650
Some how your BIOS got turned around, turn your computer off and back on, when your screen pops up for setup press the appropriate F-Key to setup. At the bottom of your screen you will have choices, Enter Default Settings and Exit. Reboot the computer and that should do it for ya. If It don't, Install a new copy of Windows, it knows your drive is there and it needs a new System Disk to read. Good Luck.
Oct 25, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
How do I get into my Easynote R4650 to change power input socket
hi,
check if ur input socket is moving , i mean a bit loose. if so then u got problem with ur DC power jack of ur Laptop. u have to get it fixed. if it seems fine then there should be problem with ur power cable of ur adapter. get it checked for short circuit.
cheers :)
Oct 22, 2008 | Computers & Internet
Packardbell easynote
First makes sure to dry the keyboard well somehow and try it after that. Turn the laptop upside down and try to let it dry.
If that does not work after it has dried well I think you need to replace your keyboard.
Meanwhile you can connect an external keyboard.
I hope that helps. I do not think you can do more.
Jan 16, 2008 | Packard Bell Easy One Silver 2101 Notebook
HP Pavilion a305w (DM181AR) PC Desktop Logo
2,835 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
