Question about Canon I990 InkJet Photo Printer
Canon pc-d320 printer catridge
This printer catridge does not show any writing when document is printed. Only to show black, dark color on page. Though the ink catridge is black, it just started this problem. Very black and dark without even seeing the white color of a plain sheet. I need help because I cannot afford to purchase a new catridge while the ink catridge is still new.
  • Teewon Jan 27, 2008
    I am seeking humanitarian assistance but have nothing financially to offer. Please assist in this direction.
    Sergeant:
  • 390 Answers
Have you tried manually cleaning where the cartridge sits. All printers eventually get blocked heads or damaged points or similar. Nine times out of ten, it turns out to be a simple. I am not familiar with you cartridge, but if you post more deatils of it i can further assist. cheers lilacgerry xxx
Posted on Feb 06, 2008
    Scholar:
  • 35 Answers
The issue you have described regarding your printer is mainly due some dirt on the printer drum, As most of the issues like this get solved when you clean the Drum, However before you start troubleshooting your printer you should try few steps to check where actually the issue lies is it the Drum or the cartridge or is it with the driver software or even with the document file software program that you are trying to print form, so try these steps below to know where the issue lies here is what you need to do,
Try to scan and print a document, by using the copy option on the printer control panel directly (Check if the print is good, if so then the issue is with either the printer driver or the document software you are trying to print).
If you find that the print output is the same which means the printer again printed a complete black page try to clean the Drum of the printer with a soft dry cloth. Please make sure that you completely disconnect the printer power cord and leave the printer powered off for sometime before you remove the printer cartridge and clean the Drum.
Alternately you can also try the old cartridge if you still have it with you just to check if the print out is fine with it, with this we can isolate the issue as we will come to know that the Toner cartridge is gone bad and you can then replace it.
However if you find the copy was fine then you can try printing a test page and check if its good. (If you find that if the test page prints okay, then try printing any other document form a different program however if you find that the test page looks like the same I mean if it is completely black then you can try to uninstall the driver and reinstall it again).
Here is how you can uninstall the driver and reinstall it.
1. Click on start, point to control panel and click on control panel.
2. Click on Add/Remove icon and select the printer driver and click o remove.
3. After the un-installation wizard is complete close all the windows and disconnect the printer form the computer.
4. Insert the driver disk in the Disk drive and install the driver.
Note: Do not connect the printer to the computer until the installation wizard asks you to do so.
If the document prints fine, you will then have to check the setting of the software programe that you were trying to print form earlier or even you can try to uninstall and reinstall the program to fix the issue.
I believe that the above mentioned steps will fix the issue however, If the issue is still not fixed please keep me posted with the latest information so that I can provide you further resolution steps accordingly.
Regards
Malik Khan
Posted on Jan 27, 2008
Dark pages produced on print or copy
you have a problem with your ink cartridge...go and get a new one...
Nov 09, 2013 | Canon imageCLASS D320 All-In-One Laser...
What is the cause for the pc-d320 canon copier to print dull
Go to Additional functions>Common settings>Toner Saver Mode and make sure its off.
And can you please explain your second question a little more.
Dec 04, 2009 | Canon PC-D340 Black and White Copier
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Words are not printed clearly in black ink. strokes through them
Your black ink has finished, try and get a new black ink catridge, remove the black ink to get the no on the catridge. good luck
Aug 24, 2009 | Canon PIXMA MP750 All-In-One InkJet...
No black when printing color
Dear Sir,
You are getting black lines in green color,and apperence of parallel light and dark lines because your colour catridge is almost empty.So solution is replace the catridge and take a printout. There is no proplem with a printer. i think it solves your problem.
good luck
chandrashekhar
Jul 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Canon PC-D320 prints only left half o document with closed cover
I had the same problem but it was caused by the scanner that was not running flash under the copier glass,if I remember correctly there are spacers on the scanner that keep the scanner to run exactly the same distance from the glass of both sides of the scanner.
On the other machine,I found a faulty scanner cable that cause a similar problem.
Jan 30, 2009 | Canon PC-D320 Copier
HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
thnx
Jan 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Not getting the black
Strongly suggest you use canon cartridges - have found all others to be rubbish
Dec 24, 2007 | Canon PIXMA iP1600 Printer
Canon I990 InkJet Photo Printer Logo
123 people viewed this question
old marine
old marine
