Question about JVC GR-D370 Mini DV Digital Camcorder
Memory card my gr-dv370u reads the card then pops up a card error message can not use the memory card/ warren
Why don't you change a memory stick and check
Posted on Jan 29, 2008
6ya staff
SOURCE:
Tip
How to Recover Pictures From Fujifilm FinePix S700 Storage Media
With 7 mega pixel camera, 10x optical zoom, 2.5 LCD, picture stabilization mode, and i-Flash intelligent Flash, the Fujifilm FinePix S700 fulfills all the requirements of any photographer. The storage media (SD and xD memory cards) used in this camera allows the photographer to save audios, videos, and photos of different sizes. Damage in storage media can occur any time, resulting in fatal consequences, like inaccessibility of data saved in the memory card. In most cases, the photographer encounters an error message stating that the card is corrupted. To overcome such corruption scenarios, the photographer needs to restore the data from an updated backup. But all photographers do not create a backup on regular basis. For them, a third-party Camera recovery software acts as a boon and helps them recover the data.
As a real-world instance, you encounter the below error message while trying to view the pictures saved in your SD card (inserted in Fujifilm FinePix S700):
"CARD ERROR"
After the above error message pops up, the data saved in the SD card becomes inaccessible.
Cause:
Few main causes for the above error message are:
1.Incorrect SD card format.
2.Incompatible SD card.
3.Memory card corruption due to unexpected camera shutdown, virus infection, and interrupted read or write operation.
Resolution:
To resolve the above error message and to access the data saved in SD card, you will need to:
1.Use a compatible SD card.
2.In case of memory card corruption, format the card in Fujifilm FinePix S700 camera. Though formatting brings the card in reusable state, all the audio, video, and picture files get deleted. To recover the deleted data, you will need to choose a powerful Camera recovery software.
Such recovery tools use effective scanning methods to ensure complete Camera data recovery. These tools can be downloaded from the Internet and used by anybody. Such applications are safe as they harm the original data saved in the memory card.
Digital camera recovery software is a world-renowned Photo Recovery utility used for recovering data from almost every type of memory card. This software ensures complete recovery of digital files, irrespective of their size or type. Compatible with Windows and Mac OS X, the read only software also recovers data from other storage media, like Zip drives, hard drives, etc.
on Jun 30, 2010 | Cameras
I've tried several 4 GB SD memory cards in my JVC GR-DF450u mini dv digital camcorder and continue to receive an Card Error Message? How do I fix it.
The GR-DF450u works with SD cards. Your 4GB cards are actually SDHC cards. While they fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Mar 19, 2011 | Cameras
While taking video it showing memory card error
remove your Card and ccheck it on your PC card reader for any errors.If so format and try. remove the Card and try to record, if there is no fault message, try to use another card.
If fault persists the card interface section may be defective.
Try to clean the contacts as a final try.
Aug 22, 2010 | JVC GR-D270US Mini DV Digital Camcorder
I put a new 4gb sandisk hc memory card into my jvc gr d270u video cam and i get card error message with or without the card unlocked.i can not go to the format menu with the card in place.
Hardware of this camcorder supports up to 2GB memory card so 4GB is more than its capacity and causing error.
Try 1GB or 2GB memory card in camcorder.
Thanks.
Jul 13, 2010 | JVC GR-D720 Mini DV Digital Camcorder
Error message Built in memory full. Also won't read memory card.
You need to format the internal memory with no card in the camera. Then, you need to format the memory card in the camera.
Feb 17, 2010 | Pentax Optio S5i Digital Camera
MicroSD card has "fatal errors"
hi i have a 4GB microSD memory card in my blackbery and it started not reading properly not it says the memory card cannot be accessed due to fatal errors i now cant access nither pictures oe music on it can someone please help me
Jan 08, 2010 | SanDisk 8GB microSDHC Memory Card with...
I recently purchased a PNY 4 gigabyte micro sd card. When ever I try to open it though, an error message pops up saying that it is "not accessible" and that "the request could not be performed because of...
Take the card back to the retail store, and get a replacement for this "defective" card.
Or, get a technician at the retail store demonstrate that he/she can read the card.
Dec 28, 2009 | PNY 4GB microSD High Capacity Mobile Media...
Fujifilm finpix z
I had this same problem and as the **** above suggested I read the manual. The problem is not in the camera it was on the memory card. There is a little (yellow in my case) slide button on the side of the memory card itself that you can slide to "Lock". Mine was inadvertantly in the Lock position, once I slid it out of the lock position, the "Card Protected" error no longer occurred on my Fujifilm FinePix Z.
Jan 17, 2008 | Fuji FinePix A350 Digital Camera
"Read only card, change to internal memory to capture"
This error message indicates that the memory card in the camera is write-protected. To take a picture, turn off the camera and insert a new card, or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
JVC GR-D370 Mini DV Digital Camcorder Logo
140 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
