Sansui g5500 receiver keeps blowing fuse 5amp.
My receiver blows fuse immediately when switched on.
  • Anonymous Apr 09, 2009
    replaced the bathroom light to a spot light, every time I switch onthe 5 amp on the board blows
    Any ideas
  • Mark Payas
    Mark Payas May 11, 2010
    what reciever is this? radio or tv set?
    Problem Solver:
  • 7 Answers
What fuse are you blowing? A fuse in the amp itself, or the fuse in your main fuse box for the house?
If it's the one in the amp, check the speaker wires for shorts, and if thats not it, then it is bad news as stated above.
If it's youre home fuse thats tripping, then you need to consult an electrician to give you another ciruit for your setup. Possible the TV is draining a lot of power.
Posted on Jan 27, 2008
    Scholar:
  • 70 Answers
I cannot seem to find any useful information for so I'll just say this from personal experiences repairing amps/receivers. Unfortuneatley there is no good news for you.
The only reason a fuse would keep blowing is if a upstream component is bad or there is a short to ground on the circuit card. If g5500 is a tube set you may get lucky as tubes either open circuit or short circuit. My suggestion, if tube, would be to power up the unit after taking the cover off and notice if there are any tubes that light up at all, will be a quick look and a number of fuses.
BUT FIRST. BEFORE YOU TAKE THE COVER OFF ANY UNIT, UNPLUG FROM WALL AND LET IT SIT FOR 2 HOURS. This gives the unit time to discharge the large capacitors in the power supply. After you wait, then take cover off being very carefull. Notice where there are capacitors (look like miniature coke cans) or any other component, you really want to avoid touching anything, And talking about touchingif you touch a tube wash your hand real well or preferably wear gloves. The oil from our skin will cause the tube to bust because of the interaction.
Another thing you can do is follow the above procedure to remove the cover but don't turn on the power.Carefully remove all the tubes. The unit might "power on" but can't be used. This would indicate one of the tubes is bad. If it does shut-down immediately, shop time.
Pure new-age component only amps/receivers are a lot harder to diagnose as there is solder work involved to test the individual part. So this need to be done in a shop as well.
I would love to help but can't, I can only guide you a bit.
Good Luck!!!
Jeff
  • oldstereoguy Aug 15, 2010
    The Sansui G-5500 is definately not tube. I would have checked this out on the web before opening my mouth and giving useless advice. All your saying is it doesn't work. He know's that!
  • tbabigian Dec 16, 2010
    I keep blowing my 1 amp fuse in my G-5500 unit, any ideas??? The other 3 fuses are fine.
    The unit doesn't power up?????
    tbabigian@comcast.net
5amp fuse for overdrive keeps blowing on ford150 xlt 4wd 2003
When you look at a factory wiring diagram & follow
the wires from the fuse that blows,where do they go?
Have to test that circuit to find a problem
Maybe a fail Solenoid or 5 other things
Sep 30, 2014 | Cars & Trucks
I have a 2004 Porsche cayenne turbo that keeps blowing the 5amp fuse in the engine compartment fuse box.
I would suggest taking it to Porsche and having them diagnose the problem...
Apr 25, 2014 | Cars & Trucks
My sansui 1000 receiver keeps blowing fuses
Fuses blow when there's an overload. This is often caused by the main power amp devices located on the heat sink. If they are transistors you can test them with an ohm meter. It will be just like you have put the two test probes together on the separate pins of the device.
Mar 24, 2013 | Audio Players & Recorders
I have a pro-sound 1000 which keeps blowing plug fuses Can you let me know what fuse should be in the plug as this maybe the problem
The fuse in the power plug is there to protect the cable. The fuse in the plug should be the same as the cable. For instance a 5amp cable should have a 5amp fuse. If the fuse blows all the time the cable could be faulty or there could be an overload in the power supply (perhaps the transformer has failed) that is causing the supply to draw more amps than the cable and fuse can cope with.
WARNING fitting a fuse higher than the cable rating could cause the cable to overheat and catch fire!
Mar 07, 2010 | Audio Players & Recorders
Blows fuse when turned on
this is a normal behavior if one of the power supply transistors have blown. take the unit to an enlectronics repair. they can either change the transistors affected (usually more than one) or replace the power supply board.
May 29, 2009 | Sansui DTV3200 32" TV
Sony STR-D565 fuse continues to blow
You could have a shorted winding in the power transformer. The diodes in the power supply can be shorted. Filter capacitors can short and send power to ground which will blow the fuse.
Apr 16, 2017 | Sony STR-D565 Receiver
I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Apr 04, 2009 | Sony STR-D565 Receiver
Old sansui amp BA-FI turn it on an it blowes the 8 amp fuse instenly
Hi again,
You might have need for the following information:
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Audio Players & Recorders
Blown Fuse
It's drawing too much power. Maybe a short in an amp. Do you have any warranty left? Double check to make sure you have the right fuse. You might also try a slow blow fuse so  you can turn it off right away as soon as the fuse starts to glow to help in diagnosing.
Apr 23, 2008 | Harman Kardon HK 3370 Receiver
992 people viewed this question
 Grubhead
Grubhead
