Question about Refrigerators
Change gas/110volt fridge element to gas 240volt
We have an american motorhome & we need to change the 110volt element to 240 volt
  • 90 Answers
I don't see the need to convert from 110 to 220. If your motor home has 220 circuits then you should be able to have it wired for 110. This would be just like in any residential home. Any 220 generator will have 110 available. 220 is just 2 hot wires, where 110 is one of those same lines and referenced to ground or neutral.
Ask an electrician if you are not sure how to wire it...
Posted on Jan 28, 2008
  • 63 Answers
You should be able to get an element thats rated 240 volt. Make sure and have the same amps as the 110 volt element
Posted on Jan 27, 2008
  • 26 Answers
You need transformer converter 110 to 240VAC.
Regards ,
Today i found my thetford fridge in c/van not working on 240 power so i turned it on to gas and it workes. Any idea what might be the problem?
the fridge works by heating crystals that creates a gas that is the refrigeration
if it works on gas then the system is good and indicates that the 240 volt heating element is not working
find a caravan repair center and have it checked out
Nov 25, 2016 | Thetford Refrigerators
Dometic fridge not working on 240 volts gas ok and 12 volt ok
The AC heater element is most likely open. Replace it and it will restore AC operation.
Sep 21, 2016 | Dometic Refrigerators
I need a motor RM870
go e-bay and type in electric motors in the search section
what you will be looking for is an electric motor with the following properties
240 volts
rpms the same as your motor or within 150 rpms
single phase
60 cycles
shaft size the same as yours and the foot mount measurements for the 4 bolts and distance from the face to the drive puller so that it aligns with the rest of the saw
Jun 14, 2016 | Saws
Fridge/freezer in a motorhome has stopped working on gas any help & advice would be greatly appreciated.
I am guessing this is a "three way fridge" 12 volt, 240 volt and lpg gas.
This is an absorbtion refrigerator and it uses heat to drive the cycle.
The things to do are;
Clean the gas jet, Piezio starter and thermocouple.
Also clean the rust, carbon and scale away from the heater tube and chimney.
Hopefully all will be good again
May 02, 2011 | Refrigerators
I replaced all parts but water heated won't get hot
You have electric water heater.
You replaced elements and thermostats but heater still won't work.
And tank was completely full of water, and water was running out of a faucet before turning power ON.
If elements are not fully immersed in water, they will instantly burn out.
If upper element is burned out, then tank will have NO hot water.
If lower element is burned out, and upper element is not burned out, then tank will have some hot water.
If elements did not burn out, then that leaves 1 main suspect: the electricity.
1) Push in ECO red reset button on upper thermostat. If ECO is tripped out, then heater will not work.
2) Click circuit breaker all the way one direction and then back the other direction to make sure breaker is latched.
3) If tank has 2 elements, then it is 240volt.
If 1 leg of 240Volt circuit is not working, then 240V appliance will not work.
240Volt circuit needs both hot wires to complete the circuit:
Buy cheap multimeter from Home Center and set dial to 240-250-277VAC
Tape tester leads to woods sticks to keep hands away from power.
Power is ON
Test across top 2 screws on upper element should show 220-240 volts.
If you have 240 at top two screws, then skip down to step 6.
If no reading across top two screws, then move to top of tank.
4) Open connection point where wire connects to heater.
Test across both insulated wires should get reading of 220-240 volts.
If no reading, move to circuit breaker box.
5) Mark water heater breaker.
Turn off all breakers except water heater breaker and main breaker. (and breaker to light fixture where box is located)
Do not hold or touch or lean against anything metal.
Stand on dry boards and wear dry clothes.
If main breaker is OFF, the big wires that connect to main breaker are still HOT.
Remove box cover.
240Volt breaker has 2 wires connected with screws.
Test across both screws for 240Volt.
See if wires are loose.
If there is no reading, then breaker is not working on one leg.
To double check, move water heater wires to another same-size 240V breaker and then put ear against water heater to listen for bubbly-fizzing sound.
6) If you are getting 240 to water heater, then wire inside tank could be loose.
Do 30 minute troubleshoot:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 09, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Can I make 2 plug in sockets from one in a 240 volt circuit
There should be NO problem in actually "Adding: another :Outlet" have you thought of a 20 - 25 Amp Power Strip, Multiway Socket, As long as you DO NOT exceed the Amperage/Wattage of the "Supply" The generator, 5000W, there will be no trouble. You MUST ensure however that this is so.
5000 Watts is 21 Amps, Watts = Amps X Volts. IE: 21Amps x 240 Volts = 5000Watts +/- 10%. So the TOTAL Amps drawn by the SUM of all the things connected must be LOWER than,say 20 AMPS.
Feb 22, 2010 | Coleman Powermate Powermate 5000W...
My dryer throws cold air not hot?
One of three things can stop a dryers element, from heating up. the big red wire going to the motors relay switch could be burned off,that is on the back of the motor itself. two, the element or the wirers conected to it have bad contacts. three the safety thermal cutout devices, have open circuts do to some sort of blockage in the vent pipe.
Jul 28, 2009 | Dryers
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jul 05, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
207 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
