Question about Sony DAV-SC5 System
Sony DAV-SC5 not playing 5.1 through the optical input from sky/blu ray
I have the DAV SC5 and have just bought a sony blu-ray player, i have connected the blu ray by optical and set the output settings. But on the DAV all i get is pro logic surround and not 5.1/DTS. Am i doing something wrong i keep reading reviews that the dav can accept 5.1 from a sky+ box b ut it does not show on the display. Can anyone help me ?
  • MARK MUMBY Jan 26, 2008
    I am using an HDMI lead to the telly , i have set the movie to 5.1 but the display does not say dolby digital or dts just pro logic
  • MARK MUMBY Jan 27, 2008
    I have the sony blu-ray BDP-S300 connected with an optical lead , double checked the settings with the manual.Sound is outputted but on the Dav the Lcd display does not show Dolby Digital or Dts when activated just Pro-Logic and also only when i select Tv function on the Dav do not get any sound through Video 2.
    President:
  • 1,950 Answers
The DAV supports Dolby Digital® DTS 5.1 audio. Make sure your blueray movie has 5.1 track and is outputting to the DAV.
Posted on Jan 26, 2008
  • 1 more comment
  • Damen Wong
    Damen Wong Jan 26, 2008
    Also, are you using the HDMI output on your Blue Ray player?
  • Damen Wong
    Damen Wong Jan 27, 2008
    So you are hooked up to your TV with HDMI and to your DAV via optical. May I please know which Blue Ray player you have. Thanks.
  • Damen Wong
    Did you make sure that downmix PCM is not enabled on your Blue Ray player on both DTS/Dolby Digital?
6ya staff
SOURCE:
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
COULD YOU TELL ME IF IT IS POSSIBLE TO CONNECT MY DAV-S500 SYSTEM TO A SONY BLU-RAY A BDP-S300 SO THAT I CAN USE IT FOR THE SURROUND SPEAKERS
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
Oct 15, 2008 | Sony DAV-S500 System
Upgrading dvd to blu-ray - how can I use my existing surround sound speakers?
Unfortunately because your existing system does not have the option of connecting an external source, such as another DVD player, the only option you have is to reuse your existing speakers and purchase another amplifier. Trying to patch another DVD into your existing unit would require a bit of technical expertise which would be more trouble than it is worth. The all-in one concept is convenient but very limiting in terms of expansion.
Oct 11, 2008 | Sony DAV-DZ100 System
No color ouput for sony Dav-dz3k
check your DVD colour setting! keep video as AUTO setting mode!
Jun 19, 2008 | Televison & Video
Sound not loud Sony DAV-IS10
I think its the fact that the speakers are pretty tiny, even tho BOSE has proved that size doesnt matter. i will agree i have a descent size home and i have to max it out all the time to watch a movie
just a design flaw IMHO.
If you need further help, reach me via phone at https://www.6ya.com/expert/abdouramane_7b3aaa187339b631
Jan 17, 2008 | Sony DAV-IS10 System
Is Sony DAV-S500 optical input compatible with optical output from Pioneer DVD player DV-566K?
I don't think this has an Optical but a Coaxial connection. You might try a coaxial audio cable not optical.
Dec 30, 2007 | Sony DAV-S500 System
How to connect other dvd or HDMI player into dav-sc5 for amblification
If your alternate DVD player has digital audio out you can make this connection via the 'optical digital in' port on the rear of the unit which corresponds to the Video 2 function. I have done this myself because the inbuilt DVD function in the Sony unit is dead (fixed once under warranty, problem recurred about a year later, same issue as other unsolved posts on this board, DVD function hangs, system won't switch off, etc. common problem with this unit, crap product).
Oct 18, 2007 | Sony DAV-SC5 System
Component Video Connection
what you have done is you are sending a component video signal from your system to your tv and the sound i assume comes through the 5.1 surrond speakers. The DVD's you play the sound would naturally come from the 5.1 surround speakers, unless your instruct the dvd player to send the sound to the tv in which case will only be played as stereo. you will need inputs on your dav system to take sound from your tv outputs or digital box by way of red and white phono leads or a digital/optical input if you have them; so as to play the sound from cable tv or sattelite tv through your 5.1 surround speakers.
Sep 04, 2007 | Sony DAV-SC5 System
Sony DAV-SC5 System Logo
655 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
