How do you turn of the engine's oil light in your infinity FX 45?
The engine oil 'warnig' light being ON indicates that you have a BAD problem with your engine oil system: this indicates that your engine is not being lubricated properly (due to low pressure) and you should get it checked immediately!
Oil warning light ON can be caused by:
- Low Engine Oil level
- Blocked oil filter
- Leaking oil filter
- Leaking oil seals
- Faulty oil pressure sensor (pretty rare) or loose sensor connector
- Also heck the obvious like loose Oil Filler cap and dip stick seal.
Hope it heps and do not drive your car without resolving this issue first as you could easily blow the engine!
