Question about Radio Shack Cinego D-1000 Multimedia Projector
Cinego d-1000 starts with picture and then shuts down
I turn it on and it plays a picture for a minute or so and then it shuts down with the white light flashing of which is the cooling mode before shuting off. I need to know if this problem is the bulb that needs replacing or if the machine is broken. I got no warning to change the bulb.
  • 167 Answers
The warning doesn't come on all projectors. Replace the bulb anyway!
Posted on Jan 26, 2008
Danby DFF282WDB stopped cooling - light comes on - any troubleshooting we can do?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are locked into the defrost mode. This is when every 8-10 hours your unit will shut down for 20-30 minutes and your defrost heater comes on and defrost your freezer cooling (Evaporator) Coil. During this cycle everything shuts down except for the light.
Your controls are usually located on the top of your fresh food section. On the bottom of your controls, near the front, left hand side there is a round hole. This is where your defrost timer is located.
With a large flat head screw driver turn clockwise. You will hear a clicking sound. Turn slowly one click a time until your unit turns on. This unit will have to be replaced. Until it is replace manually turn it off every 10 hours for 20 minutes.
Note the round stub on the left.
Feb 23, 2015 | Danby DFF282WDB 10.0 cu. ft. Freestanding...
I have an iPod Touch 4 with iOS version 4.1 It has been working flawlessly for 2+ months. Today when I shut my B&W off (while the iPod was docked), I got the flashing red light. I unplugged the...
these all relate to the power supply, sometimes when the board is faulty the aux works fine, the red light flashing may only occur when the ipod is connected, but it is all part of the same known problem. contact seller or b and w service, they should fix it.
Nov 01, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
580ex off camera shuts down after a minute or so of standby
No and no, the flash is by default programed to shut off after 1 minute .If you were using the flash on-camera, the flash would automatically power itself on when camera activity is detected but when the flash is detached, it doesn't wake back up.
To change this you have to turn off the auto shut off in the flash menu:
1. Power the flash on
2. Hold down the back light /C.Fn button until "Fn 00 0" appears on the screen
3. Rotate the selector wheel until you see "Fn 01 0"
4. Press your selector button down so that the 0 begins flashing
5. Rotate your selector wheel to change the 0 to a 1
6. Rotate the selector to the "Fn 14 0" position and set it to 1
7. Press your selector button to save this parameter
8. Press your Mode button to return to the main screen
Now your flash stays on as long as the flash switch is turned on ON, and as long as you have juice in the batteries.
Do not forget to turn off the flash after you are done.You can reverse it anytime, but you have to read the manual for that..
Same setup can be found in the manual
May 07, 2010 | Canon SPEEDLITE 580EX TTL Flash
TV PICTURE GOES OUT AND THEN SHUTS OFF
sounds like dodgy buffer board or video pcb
Sep 25, 2009 | Televison & Video
My ps3 starts to turn on for 1 second. Yellow light flashes, system shuts off, and red light blinks. Help?
HI, this is an emergency shut down, due to overheating. the yellow light is an indicator of a previous overheating issue that has damaged the power unit.
unplug the unit and, let it sit for 10 minutes to cool. after the cool off, plug the unit into the wall socket once more and, power up. if it continues to shut down and, flash the red light, this will confirm a major fault within the power unit. Contact Sony for the replacement of the power unit in this case.
***NOTE(If the unit begins to play normally after the cool-down period, you will need to purchase a cooling device to prevent future overheating issues).
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
PS3 shuts off right as its turned on
Hi, this is heat related and, this issue may have damaged your power supply board. if the red lights continue to flash after you have unplugged this unit for 5 minutes, this will confirm power board failure and, you will need to replace this circuit board.
You can purchase a replacement power supply unit at this link below and i also advise to purchase a cooling adapter for your system as well. this will prevent this form happening again in the future.
CLICK HERE TO PURCHASE A NEW POWER SUPPLY FOR YOUR PS3.
CLICK HERE TO PURCHASE YOUR MEGA POWER MINI COOLING SYSTEM FOR YOUR PS3
May 23, 2009 | Sony PlayStation 3 40GB System
MY SON'S XBOX 360 KEEPS SHUTTING OFF AFTER PLAYING FOR ABOUT 5 MINUTES. IT HAS THE FAN ATTACHED TO KEEP IT COOL, BUT IT STILL SHUTS OFF.
How many red lights do you see when the console shuts down? if its 2 red lights that means the console is overheating. there's no way to fix it but to send it in for repair
Mar 24, 2009 | Microsoft Xbox 360 White Console
Grand Wega picture going on and off; standby light flashing, sound remains on
Is the cooling fan running properly?  I'm just guessing, but it sounds like it could be overheating and shutting off, which allows it to cool off enough to turn on and overheat all over again.
Dec 09, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
244 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
