Question about Philips 9P5034C 50" Rear Projection Television
My ''9P5034C102" 50'' Philips Projection TV
When it is on, and something with a white or yellow backround comes on, the left side of the picture bounces in and out 2'' or so, but usually only when these colors are in the backround of whatever you are watching. In other words the left side of the screen does not stay to the full screen on the left side. Any ideas on how i can solve this problem?
  • Philips Master
  • 3,459 Answers
Common problem with the older projection Magnavox TV set. The opto IC chip has failed. Try - They have instructions and kits on their site.
Posted on Jul 04, 2008
Older 52 inch tv magnavox where screen is too bright or how to repair it
There two possible things based on your description.
Go to a channel that is in black and white and examine the picture--is it black and white or yellow?
These sets do have screen controls that can be adjusted but they rarely need it.
If the picture is yellow looking it could be interpreted as too bright.
If good black and white picture---stand back ten feet when you examine it---I can tell you how to adjust the sceen controls, not real easy but can be done with someone to watch screen.
I am here to help you and I have over 30 years experience with all kinds of TV sets.
Is black and white picture somewhat YELLOW LOOKING?
iF THIS INFORMATION TOLD YOU SOMETHING YOU DID NOT know rate this solution as very helpful as I do this here for free.
If you have more information or need help comment here to this solution.
Aug 13, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a Philips 32'' LCD, when I hook a DVD it plays in black and white. It will play in color in side connecter only. Please help
The side connectors are usually composite connectors meaning the have a Yellow-video Red-right audio and White-left audio connectors. Now when you are connecting them to the back and you connect the Yellow wire from the DVD player to a component input which have Green,Blue and Red connectors to the green connector, you will get a picture, but it will be in black and white. Please take moment to rate my answer. Thanks...
Nov 22, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
43'' HD projection philips tv color change
Check on ur auto covergence.Might have magnatics interference,the tv tech.use a dequasing coil to solve this prob.when it very bad,colors mast together.
Sep 12, 2009 | Philips 43PP9202 43" Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
I am trying to connect my portable DVD player to the TV in my hote; room. On the back of the TV there are red and white connection for the audio but not a yellow for the video. I have audio and i have...
You're connecting to an HD connection that's why you are seeing the purple and green.
You should have 3 composite inputs, ie. yellow, white, and green on the back, and on the side in addition to the HD ones you are currently plugged into.
Jan 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
60" Projection Tv - Approx 6 yrs old
Your CRT fluid needs to be replaced. After many years the crt cooling fluid gets a ton of alage built up in the tubes.  This will cause the screen to get a halo effect or get darker.
You only need to replace the fluid in the blue and green tubes.
Dec 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
I connected my Philips DVDR 3576H to my Sony Bravia TV and it looks like connection doesn't work. I used cables provided by Philips but I can not get access to this empty channel, on which I could get the...
The source is E1, unless you are trying to display something froma camcorder or security cam.
Philips does not provide enough cables with this product - they only provide you one set with which to PLAY a movie. You will need another red, white and yellow cable with which to RECORD. If you have a cable/satellite box, connect a 2nd red, white and yellow cord from cable box OUT to Philips AV IN. Switch the SOURCE on the Philips remote to E1, and your TV to whichever source you have the original red, white and yellow plugged into. You should get picture, and be able to record now.
Jun 20, 2008 | Philips Televison & Video
Audio out problem (magnavox MWD200G)
yellow to yellow that is video and that is ok.
red and white are the audio chanels left and rigt try to change it and your soun will be ok
Feb 07, 2008 | Philips Magnavox MWD200G DVD Player
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Color of the picture
Hi! henori,
This set is out of convergence. Go to your menu button on your remote, press it, then
find convergence and follow the directions for adjusting the convergence.
Oct 15, 2007 | Philips 55PW9363 55" Rear Projection...
Philips 9P5034C 50" Rear Projection Television Logo
331 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
