Question about Panasonic SC-HT520 System
Power cable can I get a power cable - so I can power the dvd player seperately?
    Problem Solver:
  • 8 Answers
Yes
you have to make power in put seprate then only you can make power seprate.
thank you
Posted on Jan 26, 2008
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
How to connect dvd player to tv
In order of best to worst quality, and depending on which connectors both have.
1. Hdmi ( Video and Sound in one cable )
2. RGB also known as color stream (Red,Blue, and Green RCA ) Sound Seperate ( Red and White RCA )
3. Composite ( Yellow RCA ) Sound Seperate ( Red and White RCA ) sometimes mono (single sound RCA)
4. COAX (cable) which most DVD players don't have.
All RCA connections on devices should be center color coded And grouped by connection Video 1 Video 2 ect.
Mar 16, 2010 | Philips Magnavox DVD Player MWD200F
My samsung dvd player will not read the tv
if it is not displaying video to your tv take a look at the cables and see if these is any shredding along it. Unplug everything and check the connection for any build up or damage. when you check/ clean everyhting plug everyhting back in tightly.
Turn player back on and check. If this does not work try to get a seperate pair of cables.
you may have a dead display unit on the dvd player. Check these small things first and let me know.
Mar 16, 2010 | Samsung DVD-F1080 DVD Player
Unable to operate recorder at all.
When you are turning the recorder on it is blocking the signal for cable going to the TV. Your TV will need to be on channel 3 or 4 depending on what the dvd/vcr player channel output is set to. This is why your tv is asking you to re-scan. It is losing the video signal because the dvd/vcr is taking over. The reason why the vcr with the button on the remote is because the vcr button is changing the function of the buttons on the remote to vcr. Even though the dvd/vcr is one unit they still will act like two seperate components independent of each other. They have seperate power buttons and the dvd player part may need to be hooked up seperately with rca cables to work.
Sep 26, 2009 | Daewoo DVRS05 DVD Recorder/VCR
Lost Cables
Hi,if the mains cable is seperate then you will need one, they are known as figure of eight and you will need a scart cable,you can get these from most tv electrical stores.hope this helps jamie
Mar 25, 2009 | Televison & Video
The cable that connects my JVC DVD player to surround sound power speaker has bent pins. dvd Digital theatre system th-a10
Use a bird beak pliers and gently straighten the pins out, A small bladed screw driver may assist in seperating the pins. Try getting them as close to possible as perfect. Be very careful when doing this as to much bending will break the pins. In that case you will eighter need to HARD WIRE it of possibly get a new one.
Jul 10, 2008 | JVC Televison & Video
Jvc lt40ds7bj
What model of DVD player do you have? The RF cable jacks on dvd players are only for switching the RF. All players always use AV input/output or Component input/output, the later is the best.
May 12, 2008 | Televison & Video
CLARION VRX935VD PARTS LIST
Well,it seems you have couple problems there.
About the ribbon cable the part number is 039-2144-00
And about the monitor flips up and down easily,you will need to replace the complete slide mech assy;part number 948-0646-00
you can order it from pacparts.com
Apr 19, 2008 | Clarion VRX935VD Car DVD Player
Panasonic SC-HT500
Not really an option to modify cable.Connections inside subwoofer and main unit are difficult to work with.Common problems with dvd are laser/traverse deck failure and dvd tray ailgnment.You can run a seperate Dvd player by using the Tv or Tape audio input in the receiver and run the Video cable direct to TV.
Apr 01, 2008 | Panasonic SC-HT500 System
Trinitron KV20FV12 sony
check the video cable first / next try using a s-video or hdmi cable some dvd players you have to select the way the picture is sent from the dvd player
Dec 10, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Panasonic SC-HT520 System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
