Shredders
Problem for Shredders
Generic problem for all Shredders
Paper shredder
By llcf on Jan 26, 2008
Brand new DX OP102971 strip-cut shredder and it has worked on 3 pieces of paper. It makes a clicking sound when in the "auto/on" possition and a slice of paper is placed in the feeder, but, that is it.
I have no manual and no way to trouble shoot. Can you please help me? Thank you, Teri Ericson
Same Problem
Nov 26, 2008
-   Works in reverse mode, does not shred, will not go forward . Was working fine. Is a new machine, seems forward gear stuck but will go reverse ok.
Narasimhan
-   Guest
May 28, 2008
-   Works in reverse mode, does not shred, will not go forward and only makes clicking noise. Was working fine. Is a new machine, seems forward gear stuck but will go reverse ok. Amber light on left comes on when paper is inserted.
Charles W. Smitherman Sr.
Chasmsr@charter.net
-   Guest
Best Solution
posted on Mar 02, 2008
Helpful)
fellowesrep
Rank: Guru
Rating: 87%, 144 votes
sounds like you probally have a broken gear on the drive portion of your shredder can't be more specific because I only have info on Fellowes brand shredders. You may have to contact manufacturer for more info.
Was this helpful?
Yes
No
Popular Solutions for Shredders
Questions and Unsolved Problems for Shredders
Answer
Our Martin Yale model 155 shredder does not shred, and the red light stays on when the switch is in... (More)
Answer
doesn't shred... nothing appears jammed... motor humms but doesn't engagein either shred or reverse
Answer
the as1500cd when you trun it on the red light blinks and nothing happens. is see nothing jaming it... (More)
Answer
i have a bad geer, i need a part
Answer
i have lost my pessure pad for my avery a4tr trimmer.- i had a problem with my trimmer and my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Shredders:
Top Shredder Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Shredder Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
