Webcams are either started by their specific programs or they are used by the IMs that you use. To use with the IM you must configure the IM (Skype, Yahoo Messenger, MSN or whatever you have) from their respective Tools->Options->Video to use this webcam as the default camera. Also in the Audio option you must use the built in mic of this laptop as the default mic.
Once you have done this then everytime you use the IM for video talk or just talk then the webcam and mic or just the mic will be used automatically.
While if you use the specific program to use the webcam then the webcam and mic will be used without any configuration. However, you must configure things like mirroring and colors etc so that when you move to the left the video should show you moving left and not otherwise.
Happy Holidays.
Thanks for being as precise in your description ;)
did you make any recent hardware or software changes on your computer prior to this issue?
Youshould try uninstalling the driver from device manager:
a. Click on start button.
b. In the search box type devmgmt.msc and then press enter.
c. Now locate webcam > right-click on it > select Uninstall.
d. Install the latest drivers and check.
can't seem to get to the link on fujitsu's support site
http://www.pc-ap.fujitsu.com/support/
but hope you find the driver you need or have it may be
You could also try downloading 'manycam' from manycam.com and direct your primary video capture device to it
This may work by bypassing some faults but sounds like you'll need a working driver.
good luck
