Question about T-Mobile Sidekick
Changing the sm card in my side kick 1 How?
I'm not sure where the sim card is located. Can youo walk me through it so I can change the sim card?
  • sweete Jan 28, 2008
    Wonderful and so clear with each step needed to perform this solution!
    President:
  • 625 Answers
How to Remove Your SIM
1 Turn off your device by pressing the power on/off key.
2 Your SIM card fits into a slot on the left side of your device behind the end cap. Remove the end cap using
the finger notch:
3 You will see the SIM card in its slot; press the end of the SIM in toward the device and release. The SIM
should spring gently out of its slot.
4 Remove the SIM carefully.
5 Replace the end cap by pressing the prongs in slightly and inserting the cap. Make sure the cap is flush with
the case.
How to Insert Your SIM
1 Remove the end cap covering the SIM slot using the finger notch.
2 Press the SIM card into its slot with the gold contacts facing down and the cut corner going in first, beneath
the Menu button.
When you release the SIM make sure it is locked into position and it doesn’t spring out.
3 Replace the end cap by pressing the prongs in slightly and inserting the cap. Make sure the cap is flush with
the case.
Posted on Jan 26, 2008
  • 3 Answers
Is it not on the shoulder the same as with the side kick2? check there there should be a spot where u can press down on the sim card and it will pop out
6ya staff
SOURCE:
Insert sim card is found in low signal
First:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Second:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jan 12, 2013 | Samsung GT C5130 Mobile
No sim card
Nokia C3 mobile shows no sim card means:
1.Might be your sim card got corrupt
2.Sim card slot in your handset may be damaged
3.Sim IC got damaged
these all are the reason for this problem
soluion
1.Check your sim on other mobiles.
2.Change you Sim slot after checking it.
3.Lastly check your SIM IC if neccesary change it
Aug 17, 2011 | Nokia C3 Cell Phone
Ciphering
Ciphering is mainly caused due to old sim cards.There are two ways in which youo can solve this
1)Remove your sim and insert it again and see if the problem persists
2)Go to the customer care center of operator that provided you with sim card and demand for a new sim with the same number.You'll get this for free and insert it and enjoy.
Feb 06, 2010 | Sony Ericsson W550i Cellular Phone
How do you set it up for at&t
You shouldnt have to do anything to have it call. Do you have you sim card insered correctly? do you have dual sim card option and if so make sure your card is not in slot tw and you are using sim 1 option. On the dual sim card phones SIM 2 is placed upside down against the circuit board, and SIM 1 slot is facing correctly chip is on down side, and slightly elevated off the circuit. on your front display you should see AT&T and the SIM card location it is in. You do however have to set it up to receive picture text and internet acess. I can hep you with that also
Apr 07, 2009 | Dual Electronics CECT P168 Cellular Phone
How to change the simcard of my apple 3g iphone?
The SIM card in the iPhone is removable, but it's hidden. To remove the SIM card, you need a paper clip.
We are checking to see if this voids your iPhone warranty. If you are concerned that it might, please don't perform this task.
The iPhone's SIM card is located behind this door.
1. Locate the SIM Card Slot
The slot is located at the top of the iPhone, between the headphone jack and the power button.
The paper clip is a valuable tech tool.
2. Open the Slot
Take your paper clip and insert it into the little hole. Then firmly push down until the slot pops up.
3. Remove the SIM Card
The SIM card is in a cradle. You can pop the card out of the cradle.
To replace the SIM card, put the card back in the cradle. The cradle and card are notched in a way that forces you to replace the card on the proper side. Then just slide the card back into the iPhone.
Thanks alot,
Sanjeev Kumar
Jan 22, 2009 | Apple iPhone 3G
Chang Jiang A968 Quad-band Dual SIM Mobile Phone With TV
have teh phone replaced or try manually setting the network
Dec 28, 2008 | Cell Phones
Side kick lx
1.your sim needs a password
2.turn off ur sidekick 3
3.place ur cingular card in
4.turn on sidekick 3
5.itz gunna ask you for a special code ignore it
6. go to settings den sim center
7. if ur sim lock is disabled jus enable it
8.den change ur sin pin to wateva you want
9.once u change it you will signals bars go up
10.go 2 settings network options
11. press scan scan select manually
12. select ur network
13. and datz it your sim iz workin on sidekick 3
if u turn it off u will have 2 do da same process again
this will work with all sidekicks
Oct 24, 2008 | T-Mobile Sidekick
Phone code
The phone code locks your t830 to the inserted SIM card, if you change the SIM the unit asks for this code. If you don't know the code (ebay?) there are three possibilities:
1. ask the formerly owner for the key
2. insert the "old" SIM-Card and delete the key in the phone-settings-menu by pressing "forgot code" and entering only the SIM-Card-Code
3. send your device to FSC with your bill (ebay?)
KICK YOURSELF OR THE EBAY-SELLER FOR FORGETTING SECURITY-CODES!
Dec 14, 2007 | Fujitsu Siemens Pocket LOOX T830...
T-Mobile Sidekick Logo
243 people viewed this question
Top T-Mobile Computers & Internet Experts
Ekse
Marvin
Marvin
markpain
Level 1 Expert
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
