The firing order is 1, 3, 4, 2. If all the leads have been pulled off the dizzy cap, you'll have to remove No 1 spark plug (leave it threaded into the plug hole by 1 turn) and the dizzy cap. Turn the motor over by hand in the clockwise direction and listen for air being forced out of the No 1 plug hole. When you start to hear that, it means you are approaching TDC on No 1 cylinder. Now look at the front crankshaft pulley and stop turning the engine when the mark on the pulley is close to the marks on the timing belt cover. It doesn't have to be exact (unless you've removed the dizzy). Now where the dizzy rotor is pointing is where No 1 lead has to be fitted. Observe the direction of rotation of the rotor and the next point it comes to will be where you fit No 3 lead; No 4 lead next; and finally No 2 lead.
