Question about Bose (321GS) System
Bose 321 Remote not working
I got my bose 321 system 40 days ago and it was working great. all of sudden the remote stopped working. I called the support and they replaced new remote. still it is not working ..
any ideas.. please help
  • 6 more comments
  • capecodjjc Mar 06, 2008
    same prob here, hoe do u ck the ir sensor?
    JC
  • trix937 Apr 21, 2008
    how easy is it to replace the IR sensor? My remote will not communicate and universal remote can not pick up the signal.
  • nknc May 10, 2008
    bose remote not functioning at all
  • Anonymous Aug 02, 2008
    remote does not work it will turn on my Sony TV but will not fuction
  • Mimzey Oct 11, 2008
    Our Bose stopped working completely. The DVD was stuck (no disc message), so we turned it off but now it won't come back on. Everyone says to remove the six screws on the bottom, but I don't have any screws. I released four pressure clips on the bottom of the face but the face will not slide up or out. Help! Bose Media System AV3-2-1
  • Anonymous Jan 01, 2009
  • jlgoat Mar 04, 2009
    Remote is not working. The red light doesn't even come on. Fresh batteries do not help.
  • baldeagle25 Mar 22, 2009
    My universal remote works but not my Bose 321 remote. I have changed batteries...  still no red light... Yet my universal remote still controls my system.  I like my Bose remote better....... help
Pull off the front panel, be carefull there is a ribbon attached. Detach the ribbon. There are 2 ribbons attached to the front panel, one that leads to the IR (remote sensor) and other for the controls on the top of the unit.
Most likely the ribbon that goes to the IR sensor detached itself, this is common if the unit is dropped etc. Insert the ribbons (2) re-attach the front panel and the remote should work fine. You'll notice some tape on the IR ribbon, I suggest using some stronger tape, BOSE tape thats not very good.
This happened to me on my 3-2-1 GS II system and fixed it.
Posted on Jul 04, 2008
  • Phil LaNasa
    Phil LaNasa Nov 07, 2013
    Huge! It worked. Note, even though it's not visible, there is a little bit of slack in the ribbon for the remote. You can "pull it out" a little bit. FYI: This is the wider ribbon.
  • 3 Answers
I just have the Bose powered speaker system (lifestyle, I think - 2 speakers and a subwoofer) attached to my airport express. I used to think the problem was with the universal remote control, but reading on this and another forum led to the solution - the problem is with the receiver (this speaker system has a small receiver, about the size of a cigarette pack). Just switch off and switch on the speaker system, and it starts sensing the remote control again.
Posted on Sep 01, 2008
I just fixed mine using the tape method. the ir receiver was detached. to access the ir ribbon, the silver faceplate must come off, (re plug the unit and eject it, then disconnect it while it's ejected. dvd face plate comes off by detaching the spring loaded clip). once that's off, lift on the top edge and bottom edge of silver faceplate to get it off, then slide it out. the ir ribbon is underneath the top electronic control unit(where the power, eject buttons are). it's easier to unplug it from the the ir using tweezers, but be very careful. once the top controller is out, resecure with tape(i used small strip of duct tape). then re install in reverse...enjoy.
Posted on Feb 09, 2009
    Problem Solver:
  • 8 Answers
DEAR
YOUR REMOTE MAY OK PROBLEM IS WITH YOUR SYSTEM PL CHECK IR SESOER
THANK YOU
Posted on Jan 26, 2008
  • Jamanice Apr 15, 2011
    I had this problem too and called Bose and they told me what to do over the phone. It took 1 minute.
    Turn off the system
    press and hold middle button on the display box - you should see "house code" come up
    while holding tap the far left button several times until you see "flash commit"
    let go of middle button
    press far right button
    press on hold the middle button again while press any button on your remote.
    turn your system on with your remote
    Hope this helps
  • Glenn Namian Dec 25, 2011
    I just unplugged the acoustimass cable from the main box, waited 10 seconds, reconnected, and everything worked. Essentially reboot the main box.
I have also been having issues with the 321 bose system and I am trying this method now. I have taken out the 6 screws from underneathe the unit and pulled off the top of the unit to access the front panel. I've used a flat head to dislodge the front panel and the dvd drive seems to be stuck as I am trying to full the front panel off. I can see the two ribbons and wider of the two is disconnected but I don't see where it goes nor have access because I don't want to break the front panel off without a manual. Does anyone know a step by step procedure, or did I miss a screw, or does anyone have a manual on these POS units! Thanks.
Posted on Aug 26, 2008
It worked for me. I had to open the panel only to find that ribon was plugged off. To answer anothe question in this forum on how to it open the panel - there is no such hidden clip or lock. I played around for a bit, twisted and turned till it came out. Everything after that was a cake walk. I'll admit taking the front panel out was the biggest challange. I actually cut my finger doing that :)
Posted on Feb 11, 2010
THIS WAS GREAT INFO zoozack FIX MY PROBLEM RIGHT AWAY.
THANK YOU.
Posted on Aug 18, 2008
This really works...my husband and I just did this (took off the "face", found the two front ribbons, made sure both were plugged all the way in and then taped them down just in case) and the remote - or should I say the sensor - is now working perfectly! THANKS!!!
Posted on May 29, 2010
    New Friend:
Thanks zoozack. I just fixed my Bose AV321 series 2 with the remote control didn't communicate with media center.There are 6 long screws at the bottom and 3 short crews at the front panel. The connector from IR sensor connects to circuit board by 4 tiny pins,easy to drop out, you need to resolder.And in order to take off the front panel of cd/dvd tray, need to pull bottom first and top after.
Anh Nguyen. 01/19/2016
Posted on Jan 20, 2016
Bose needs to quit making stuff in mexico.
Posted on Oct 29, 2012
After sending my unit back 3x for the same problem of DVDs freezing up, Bose wanted to charge me $100 to fix it again. Now the remote quit working. Does anyone know how to change radio stations manually????
Posted on Aug 24, 2012
Will a universal remote work on a Bose 321? If so, which one?
Posted on Nov 18, 2008
I lost my Bose 321 remote I have a Sony RM-YD010 and can't find the correct code to use this last remote for my Bose system. I have tried many codes suggested and nothing works. Help. Thanks
BOSE Uses different type of protocol in their remote . You will not be able to program any remote for your bose system. So try to buy its original remote.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 14, 2016 | Sony Televison & Video
Bose 321 dvd and remote
hello.
Clean out the battery connection inside the battery case. Incase this work disassemble your remote and find any fault connection in it. or let the repair man do it.
If the remote work change the setting press PBC mode this will change the color. or refer to the manual for changing view setting.
melnavz
Mar 31, 2008 | Bose 3 2 1 GSX System
Bose 321 device code for Kogan UHD TV
Your Bose remote may not work with your Kogan TV.
Aug 12, 2016 | Bose 321 GS series II
I have a bose 321 system and I was wondering if there is a way to turn the bass up and down without the remote. I lost it
321 Home Entertainment System - Bose Product Support
worldwide.bose.com/productsupport/.../321.../page.htm...
Bose CorporationDiscover product support for your 321 home entertainment system. ... Learn how to setup and place your system components. more » ... You can adjust bass and treble levels to suit your listening preferences and your ... Discover how to use buttons on your remote and media center control panel to ... Get Adobe Reader.
[PDF]3•2•1 Home Entertainment System - Bose
worldwide.bose.com/axa/assets/pdf/.../og_321.pdf
Bose CorporationJan 29, 2002 - within the system enclosure that may be of sufficient magnitude to constitute a risk of electric .... Turning off the internal speakers in your TV .
Jan 18, 2016 | Bose 321 Series Iii Dvd Home Entertainment...
I have a Bose 321 GS III Cinema system. What code do I have to program in the Bose remote control to control my Motorola 1960 Cable tuner? The codes in the Bose manual do not work, so I expect that the...
having same problem with my bose 321 GSX. my mom just got shaw digital and likes the shaw remote better than the bose one. I can program the bose remote to do everything but can't seem to do it for the shaw remote. I think i need a code for bose as a reciever? I dunno... any help would be good eh!
Aug 10, 2010 | Bose (321GS) System
Bose 321 system stuck at 30 volume
Is vol buttons button on unit do the same, try remote.
If not try unplug from wall wait hour and try agian, if not bose update cd..
Aug 02, 2009 | Bose (321GS) System
My bose 321 system remote control sometime works and sometime doesn't.
When we try to use the remote the red light glows which I never saw glowing when it was working properly.What could be the problem?
Jan 03, 2008 | Bose RC-18S Remote Control
Bose 321
I have same issue. This happened on 12/31/2007 after 13 months of operation. Though remote is not controlling the unit, it controls TV. I went to BOSE showroom (Chennai, India) and remote worked perfectly with their GS display unit. Then I went to service center. Serviceman promised me to send a CD with software upgrade. Let me wait for a day or 2 receive CD and test it. Have you got any solution.
Dec 28, 2007 | Bose (321GS) System
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Bose (321GS) System Logo
20,759 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
