Question about Phase Linear UDV9010 Car DVD Player
How to fix if or send it off
My screen stalls when it's cold or to hot
  • 3 Answers
Check to see if the cooling fan is still working. But most of the time theres nothing wrong with the stereo, like all electronics, in extreme conditions it stalls or freezes up
Posted on Feb 20, 2008
Revs up and down and shuts down will not idle cold
tuned up is it, (spark parts, filters?)
stalls? hot and cold or only cold.
or due to stalling cold can never get engine hot to 180F.?
there are over 50 causes, the tests are 10x less.
1: can you save the stall with a fast right foot.???????
and what size engine?
May 06, 2015 | 2002 Isuzu Rodeo
Why does 1992 isuzu trooper runs for a few seconds then stalls and won't keep running? I've replaced the fuel pump,fuel pressure regulator,and fuel filter. Spark plugs and wires have been changed also
hot or cold engine or both?
which engine, to work on one, you need to know what it is
and what EFI system it uses. or its all just a crap shoot.
no new distributor cap and rotor why skip the full tune up,. why?
first questions.
1: can you save the stall with a a fast right foot.
2: why change out pump etc, if fuel pressure is at spec, a $20 tool would have saved you 5 hours hard labor and bath in fuel? why?
Stalls 101.:
the engine can stall for over 50 reasons are you going to do all 50?
surely not. why not consider diagnosis.. as a path.
1: car stalls, right foot saves it. and can drive fast if i keep foot busy.
a: ISC stuck closed.
b: EGR valve stuck open (depends on which engine options)
c: low compression on one or more cylinders.
2: can\'t save it from stalling (right foot)
a: fuel pressure is low. (wires bad.)
b: lost spark, for any reasons.
c: lost 12vdc to the EFI system( killing spark and fueling)
stalls.
hot or cold or both
stalls, can save it or not, hot and cold
hot restarts are easy and it runs good hot,yes./no.
there is lots more to it, then just stalls. lots more.
Aug 28, 2014 | 1992 Isuzu Trooper
I have a 1.6 auto petrol renault modus reg55.After I turn on the engine if I push a hard break the rev falling down and the engine stop.But only at the first few miles. Any idea for this problem? Thanks
reg codes only work in UK, use real years..... so ROTW can tell.
please, tell what it does good and bad driving, idling , parked, moviing
hot and cold engine, full power from engine on hills.
stalling (it stalls) but when does it stall, under what conditions. hot or cold engine. only at stop lights hot. or>????
when an engine is cold the RPM is very high (iAC device) and it will not stall cold , if it does that is key.
if it never stalls hot. and runs perfect hot say so.
all these, clues build evidence. to what is wrong.
then we do tests.
PS: ever think to get that 60,000 mile (100km) tuneup>> now be it.
Jul 01, 2014 | Cars & Trucks
Stalling
The CDI box could be bad or the coil could be breaking down so maybe a new coil would fix you up they only run around 20$ cdi box on the other hand can cost an easy 100$ or better you might also try changing the oil but make sure to buy kinda thick oil cause it's cold out
Jan 13, 2014 | Suzuki KingQuad 400 ASi 4X4 ATVs
Wont idle when cold / stops running when hot
stalls.
hot or cold , does fast right foot save it easy?
critical test, that.!!
there are 50 things to stall it.
but only 5 basics.
but need to know the fast foot answer
Dec 21, 2013 | 1998 Honda Accord
My 1996 nissan altima sputters and stalls at 1200 to 1500 rpms it only happens when it is warm
1996 nissan altima coolant temperature sensor When these sensors go bad it sends a signal the the cars module and tries to shut down car. There are two sensors....one controls hot/cold gauge inside car....the other one sends signal to module. there not that hard to change out....Most can be taken out with a 19mm deep socket wrench. Cost around $25.00 I hope this fixes you car.....Good luck.
Aug 24, 2013 | Nissan Altima Cars & Trucks
500 pop 2008 vehicle stalling intermitantly with engine hot or cold.
Have you had the electronics tested for fault codes? That is the 1st step when you have a problem like this.
Apr 23, 2012 | 2008 Fiat 500 1.2
My van starts right up when its cold but after it gets hot and i slow down it stalls and won't start again til it cools down hours later all my vacum hoses are attached what is wrong?
Change the coolant sensor but make sure the coolant is full up in the radiator. When this sensor malfunctions, it sends the incorrect signal to the computor & it stays in the incorrect timing mode & the car stalls. The sensor is close to the thermostat housing. Good luck. When the engine is hot, unplug the sensor & it will start immediately. Again, good luck!
Oct 29, 2010 | 1986 Plymouth Voyager
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Apr 18, 2009 | Kenmore 23822 Top Load Washer
1988 truck stalls when hot.
maybe your running hot, check your coolant to water ratio.
May 22, 2017 | GMC K1500 Cars & Trucks
Phase Linear UDV9010 Car DVD Player Logo
61 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
