Question about Technics SA-AX540 Receiver
Over load on Technics SA-GX130
When I trun my receiver on the over load light runs on in about 2 seconds without anything plugged into it. The problem occured one day when I was listing to music through the vcr-1 input at a reasonable level, not very loud and it stopped playing and the light was on? Not sure what I can do.
contact me at [email protected] Thanks
Neal
  • jshess Feb 28, 2008
    I have the same problem with the same model of receiver except that it started some months ago. My son, who owned the receiver, was going to throw it out but I suggested he let me look at it. I downloaded a PDF file of the service manual for this model receiver but it must be a different revision because it has no mention of the "Over Load" light and it does have a fan which I don't have. I have checked the obvious stuff in the power supply and can not find any problems there. Someone told me that it when the "overload" light comes on in this receiver that it indicates a power supply problem but without a schematic that included the overload feature, I can't be sure if that is the case or not.
    Any help would be appreciated. Else, I will just let this thing continue its trip to the dump.
    Thanks in advance
    John
  • Anonymous Apr 20, 2008
    Tengo un problema de ruido en un canal , es posible coseguir el Integrado de saliad
  • 515 Answers
There is no easy fix for this. Your unit is power itself down to protect itself. There is an obvious short. You will need seek professional assistance.
- OPTiC
Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
6ya staff
SOURCE:
The HDMI light on my receiver is flashing. The power button does nothing, and no other inputs do anything. There is nothing on the screen, and neither of the knobs do anything. I unplugged it for a...
For model vsx-523-k with HDMI light flashing.... PLUG THE UNIT IN AND WITH THE HDMI LIGHT FLASHING "PRESS THE POWER AND THE AVANCED SURROUND BUTTON SIMULTANEOUSLY. .. AND HOLD FOR 5 SECONDS this clear the error. .
Aug 22, 2013 | Televison & Video
Can not trun my hp dv1217 notebook on even with the DC adapter.
1. Remove Battery
2. Remove all cables attached to the computer including AC Adapter
3. Hold on the power button for 60 seconds
4. Release power button and install the battery.
5. Power on the laptop
6. When Windows loads, attached the power cable
7. issue resolved.
Mar 04, 2011 | HP Computers & Internet
For the past two days, the DVR is unresponsive for about 2-3 hours in the morning. The unit seems to cycle on and off by itself every 30-40 seconds or so and I hear the fan running each time. I am not...
Hello, this is Luke, let me help you on your concern. A DVR which reboots by itself always means a power failure. Try to isolate the issue first by plugging in the DVR to a good power outlet. I suggest to plug it directly to a working wall outlet to make sure that it is not a power surge suppressor or a power strip device problem. Give the DVR at least 5 minutes to boot up. Allow it to do its own thing, and it should come on by itself. You will hear a spinning sound coming off it, which is normal. Within 5 minutes you should see a message on your tv screen. A good indicator that the receiver is on, are lights on it. Orange for mode, Green for TV1 And blue for TV2. You should have at least the orange light on, when the DVR on. Do a reset if it will not power on after 5 minutes, unplug the DISH receiver for 10 seconds and plug back in. Please have TV1 on during the whole process. Let me know if this help. Have a great day.
Jan 24, 2011 | DISH Network ViP722 DTV Receiver /...
I have been having issues with the receiver "losing" the signal or interupting the signal from my blu-ray player and previously when using a dvd player. the DVD continues to run and when the...
That's one of several reasons I can think of to bypass the receiver's handling of any video I care about. I only let my receiver 'see' the audio from anything external and send it's own video to the TV so I can see its internal menus.
I don't know what can be done if your video-carrying cables are all good.
Jan 01, 2011 | Onkyo TX-SR706 Receiver
Yamaha RX-V595a receiver shuts off 2 seconds after its powered on
The first thing called out is the impedance switch on the back is not fully in one or the other position. Cycle the switch back and forth to make sure it will 'read' each setting, then turn it on.
Also make sure you if you have anything connected to its convenience outlets that they are not drawing more current than is allowed.
Did you buy it used or new?
Mar 09, 2010 | Yamaha RX-V595A Receiver
Logitech cordless mouse is not working.
It could be the receiver is bad or the driver is not properly installed. Try to uninstall/reinstall the driver. Try also connecting the receiver into different USB ports of your computer
If same problem occurs, try installing the driver and connect the receiver into another computer to isolate the problem. You can uninstall the software after that.
If same thing happens, then contact the manufacturer to RMA the device.
Have a great day!
Sep 13, 2009 | Logitech Cordless Mouse
My ps3 isnt showing anything, its just blank whenever i try to trun it on the screen is just blank, but when i put a disk in, i see a little loading circle on the top right hand corner any help will be...
HOld the power button down while its on for 10 seconds. DO this 2 or 3 times. you will hear it beep once, do NOT let go hold it for the FULL 10 seconds to do a full RESTART!!! That should help you out.
Jun 04, 2009 | Sony Playstation 3 (PS3) Console
LCD monitor turns off after 2 seconds from boot
Try to see the video card and fell if it is hot, if the fan is running when turn on. There is a part of your computer that is hot, that when reach to that temperature it trun blank or off.
Thanks
Nov 19, 2008 | Dell E173FPc 17" TFT LCD Flat Panel...
Technics SA-AX540 Receiver Logo
1,389 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
