Question about RCA 32V524T TV
Airane WE WERE WATCHING TV LAST NIGHT AND THE TV SHUT OFF BY ITSELF. IT WOULDNT TURN ON BY THE POWER BUTTON OR THE REMOTE I UNPLUGGED IT AND TURNED IT ON AFTER BUT THE GREEN LIGHT ON THE TV JUST KEEPS FLASHING NO PICTURE OR SOUND. IVE ONLY HAD THIS TV FOR A YEAR WHAT COULD IT BE?
  • RCA Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
E500i-B1 won't come on.
Suspect a failing power supply
Jan 13, 2017 | Televison & Video
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
TV won't stay on
You will have to call an Authorized Panasonic Servicer. Any modules bought from them requires an authorization. Since your not a service center, it's going to be almost impossible for you to do anything. Play it safe and have it looked at.
Aug 20, 2009 | Panasonic TH-50PX75U Plasma HDTV
Samsung pn50a450 plasma TV turned off by itself
first unplug it for 10 min then retry it. otherwise it is the power supply, the low voltage and high voltage supply are on the same board, have your tech send it in to be rebuilt if he is unable to do it him or her self.
Jul 23, 2009 | Televison & Video
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
TV WENT OFF BY ITSSELF
This TV has reached the end of its (short) life. Needs to be replaced.
You can try looking at what kind of TV it is, what model, and look at the manufacturer's web site, check for the manual, look up what it means when the green light flashes. Might be a code that means something but I think the TV is dead.
May 15, 2008 | Televison & Video
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Wont turn on at all...
read info at ctechnicians.com email for questions
Dec 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
This may denote a proble in either your switching powers supply or your Horizontal section derived high voltage power supply. These are both very dangerous sections in your television. My next question is important; do you have a background in electronics? If not I would not advise you working on this problem yourself and that you take the TV to a repair shop for servicing. If you do have some background in electronics, I would like for you to make the following obeservations: What was the TV doing (it actions)prior to it going out? Did you hear any sounds before it went out like buzzing or crackling? What do you hear when you try to turn it on now, clicking? These questions are just to develop some background into what might be happening to your set. Thank you, Shuttle83
Oct 07, 2007 | RCA 32V524T TV
RCA 32V524T TV Logo
248 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
