Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
My mitsubishi vs 5071
By trucker70 on Jan 26, 2008
my 60" rear projection tv comes on and has sound but no picture. the bottom of the three tubes glow but just a black screen remains.
Comments:
Jan 27, 2008
- totally black no blue snow just plain black screen
Jan 27, 2008
- how can i get a manual for this model? model VS5071
Jan 27, 2008
- was you able to find the link?
Jan 27, 2008
- 930b552 hopefully that is it.
Jan 27, 2008
- How do i pull the board? Just pull straight up or do i have to unsolder it?
Jan 27, 2008
- I don't have any capacitors. how much is a pip board? and how do i remove it?
Jan 28, 2008
- Okbut how much do PIP boards usually cost? And i am so sorry to be bugging you so much.
Jan 28, 2008
- So i hook up the capacitors to the pip board itself or do i hook them up to where the pip board connects in the tv?
Jan 28, 2008
- Can my tv work without the pip board at all? The last tech i talked to said i could bypass the pip board totally and since i dont ever use pip i figured that would be ok. I just need to know how to do it. If anyone can give me directions on how to do it i would appreciate it very much.
Clarification Request
Posted by gia914 on Dec 25, 2008
The problem is VS-5071 has no video, I did the PIP jumper trick and replaced the vertical IC and repaired all cold sodered joints and still no video. Can anyone help me?
Same Problem
Jan 18, 2009
-   Mitsubishi Model VS-5071. Does not turn on at all. All connections are ok. Does it need a new tube of some sort? -   patti2008a
Jul 29, 2008
-   no picture but sound can access all setup pages via menu but no component inputs-   dgwmoney
Best Solution
posted on Jan 26, 2008
Helpful)
Slinteriors
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 3850 votes
You might have a bad PIP board, When you say NO picture. Is it totally blacked out or blacked out with "blue snow". The PIP has been alot of problems in this chassis and you will experience what your describing. Capacitors are the root of the PIP boards failure. Let me know if I can assist you further.
Comments:
Jan 27, 2008
- I will post a link shortly where you can get one along with free support to hep diagnose your set, Just have to check if they have that Chassis. I will get back to you shortly.
Jan 27, 2008
- No i wasnt. am still looking thatsa hard model to find info on. It s simallar to the VZ2 from 1994 But VZ2 doesnt cover that model. Do you have a PIP board in that chassis? If so it should be on the left board with the cluster of boards standing upright. The smallest board. If you do pull tht board and give me the numbes off that.
Jan 27, 2008
- Here is a trick to bypass that module to see if your problem lies in that module cause both horizontal and vertical circuits pass through that module. Do you have (2) 4.7uf @ 50 volt capacitors on hand. Take the PIP board out. Those numbers you gave were the PIP. And on the connector where the module plugs in Jump pins7 to 9 with 1 capacitor +lead in 7 -lead in 9 take the other capacitor and jump pins 5 to 11 + lead on 5. - negative lead on 11. Solder a small piece of wire so the leads dont touch as the pass each other. Just push the wires from the caps into the connector. No need to solder then try to power up your set. Let me know what happens.
Jan 28, 2008
- The modle clips in to plastic sockets. There is two sockets and they each have a plastic retaining lock. Just pry the little clip away from the clip and pull the module up. I will check on the availability of the module for you. You may want to try the bypass just to make sure you need the module radio shack has the capacitors for about 1.00 each.
Jan 28, 2008
- depends on the availability between 150 and 300
Jan 28, 2008
- Thats how you bypass with the two capacitors they plug directly into the socket that you took the pip module out. Its the clip with eleven pin sockets.
Was this helpful?
Yes
No
Solution #2
posted on Apr 12, 2008
Not Rated)
kosomak
Rank: Apprentice
Rating: 0%, 0 votes
okay here is the deal i have a mitsubishi tv the searal # on it is vs5071 the problem iss the pictuer is plury and i need help fixing it thanks.
Was this helpful?
Yes
No
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS... (More)
Answer
the problem for the t.v toshiba 42av500utv is that you can hear it but the screen isnt working
Answer
I have a Sharp Aquos LC-32BD6X out of warrenty. Turns on with picture and sound fine but after 30 or... (More)
Answer
how do you clean hitachi rear projection mirrors - we have a blue haze like a tunnel
Describe your Projection Televisions problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Colton, CA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
