Sony KP-53V80 53" Rear Projection Television Logo
Posted on Dec 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony model KP-53V80 wont show picture or sound
MY TV died, it shows a line through the middle of the screen and no sound or other pictures can be brought up. Sony model KP-53V80
My son said they where playing X box and it just died. With a strange sound and no more picture or sound??
Anonymous
Level 2:
New Friend:
  • Expert 139 Answers
  • Posted on Dec 27, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
139
Questions
0
Helped
25919
Points
232
YOU LOST VERTICAL DEFLECTION THIS WILL REQUIRE PARTS REPLACEMENT
1helpful
My 12 year old Sony KP-53V80 TV suddenly turned off and will not show a picture just a small rainbow at the top of the screen, then a whistling sound, crack and turns back off. can you help?
sounds like the inverter went bad...There's a high voltage device in there that runs the whole "picture" thing. There are capacitors involved with it that have probably failed leading to this mess.. That would be what that "crack" is...If you try to turn it back on does it just "click " and then stay off?
It is showing a double picture
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
My sony kp-57hw40 projection tv picture is not as bright as usual. There is blue arc lines that show up at the bottom of the screen.
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2helpful
2answers
Sony rear projector TV problem, KP-61v35
This is a problem with the vertical circuit. This can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Let me know if you wish to attempt the repair and I will supply additional details and instructions.
Dan
I have a Sony Projection TV KP-53v80. I tried to turn it on today bu there is no picture no sound. The Timer/Standby indicator flashes 4 times. What does this mean?
No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
Check IC1509, Q1505
Please rate this solution
Sony big screen tv model# kp-53v80
It can be just an adjustment of your screen control. There is a "sweet spot" on the control where it allows the picture to come through. This is a common problem with sets that are getting old. If there is a problem with the high voltage from the color tubes then it will shut down the video until the problem is gone and it is safe again to show the picture. This is known as going into a shutdown procedure to protect the set. A technician will be needed to fix your problem since it will require proper troubleshooting and knowledge of high voltage system and safety procedures.
2answers
Sony kp-53v80
Heres how you get into the service menu. BUT be very careful write down anything that you change as this can screw your set up and if you write down everything you will be able to change it back if it affects your set. You may want to consider getting the service manual which will explain all the details on the convergence adjustments. If so let me know and I will post a link where you can get one along with free tech support to help you out with it.
Put the TV in Standby Mode.
  • Then press the following buttons on the remote:
    {DISPLAY} {5} {VOL+} {POWER}
    or
    {DISPLAY} {5} {POWER}
    or
    {DISPLAY} {5} {PICTURE} {POWER}
    or
    {DISPLAY} {5} {VOL+} {PICTURE} {POWER}
  • The TV will turn on with the Service Menu displayed.
  • Use numbers {1} and {4} to select the item to adjust.
  • Use numbers {3} and {6} to adjust the value of the data.
  • Press {MUTE} then {ENTER} to save new settings.
  • The words "WRITE" in red will show up in the upper right corner if saved.
  • Turn the TV off to exit the service menu.
  • 0helpful
    Lines in picture
    You may have to re-adjust the screen drive. It sounds as though it may be just a bit high. If it's not that, you may be getting a bad picture tube. I hope this has helped in some way.
    Ed
    NC Electronics
    Mills, Wyoming
    2answers
    Sony 52"
    i have a sony kp-53v80 i have a double vision or red lines on the left side of the screen. a repair guy fix it once by using the remote and puting in a code that brought up a white grid and it showed the red was out of line and he moved it back in line and it only took a few seconds to fix ... how do i get to that grid using the remote
    Top Sony Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ZJ Limited
    ZJ Limited
    matt martin
    matt martin
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
