Rca 61130 rear projection tv has pink haze
Over a white screen it looks light pink with distinct horizontal lines .picture is generally ok otherwise what could this be?
  • johnnyjunk Jan 26, 2008
    do you mean the red green mixture in the tv menu or an adjustment inside the tv?
I tried that with no real improvement. I think there is actually screen burn from the guide channel of my satellite box because it seems to line up with the boxes and the top is unaffected. If this is screen burn is there a way to repair the screen?
Posted on Jan 31, 2008
  • 8,617 Answers
Try adjusting your Red screen control down just a little. This is usually a sign of the red crt developing a short. Often just turning the Red drive down just a bit will make the retrace lines disappear if not you will eventually need a new CRT or repairs in the red drive circuitry. Hope this helps.
Posted on Jan 26, 2008
  • Sonny Berry
    Sonny Berry Jan 26, 2008
    Inside the TV there is usually a block with 6 buttons 3 focous controls and 3 screen controls. Some models have it on the PC board pluged into the end of the tube in that case each tubes pc board will have a control switch on it for that tubes drive if its not with the 3 buttons o the focus block.
47''REAR PROJECTION PICTURE PROBLEM PANOSONIC
Hi,If you are experiencing color distortion,pixilation,white dots,vertical or horizontal lines it might be time to replace the DMD board. Digital Micromirror Device (DMD), This is how it works: http://electronics.howstuffworks.com/dlp1.htm
Mar 30, 2010 | Televison & Video
My RCA console tv has white horizontal lines accross screen, picture is very light and sound is ok, very frustrating. I know its an old tv, but appreciate any response. Thanks
Cold solder joints on the flyback transformer circuit board - probably because RCA used feed-thru steel rivets on their boards. Re-solder the connections using a good solder flux for clean solder joints and this will fix prob. The joints with the dull, pitted finish are the problem joints.
S. Hampton
Jan 26, 2010 | RCA G35773SK 35" TV
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
Yellow corners on 56" RCA Rear Projection TV
possibly cleaning of the lens and the mirror might improve the picture. it could be what is termed a glycol or fliuid issue. dirty glycol will cause this yellow halo effect. the glycol came be changed a rather expensive and evovled repair i think
Jan 15, 2008 | RCA P46810LV 46" Rear Projection...
My rca d61130 projection tv has red/pink faint lines
It sounds as thought he convergance needs to be adjusted. You will need to push the auto adjust button or go into the menu and do a manuel adjust. Any adjusting instructions should be listed in your Operator Manuel. If you require more assistance in this matter, please write back. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | RCA D61W20 61" Rear Projection Television
White horizontal lines on screen
Replace all electrolitic capacitors on the Proscan pcb.
Dec 11, 2007 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Televison & Video Logo
277 people viewed this question
Top Televison & Video Experts
