Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Copying I just bought a Kingston 2GB Data Traveler and I am unable to transfer my files on to it. I keep getting error copying file or folder. Am I doing something wrong? I am working on WIN XP.
  • 3 more comments
  • dianev1978 Jan 26, 2008
    It reads Error copying file or folder Cannot copy file 001: Cannot find the specified file. Make sure you specify the correct path and file name.
    No .. there is no other error that pops up..
    When I go to Disk Management there is no drive there. Just the two drives that I already have partitioned.
    Sorry dumb question but where would I check that? And if the proper drivers aren't installed where do I go to get the right ones. Thanks for your help and quick response.
  • Sashilo Jan 14, 2009
    I have a 8GB Kingston dataTraveler and I can not write anything on it. only on my computer. on every other PC is OK. And other USB storage devices work fine on my PC. I tried everything, but so far I found no solution. I can copy files from it, but not on it.
  • Alexander Selby
    Alexander Selby May 11, 2010
    Is there any ERROR Code, or other info when it pops up?
    Sergeant:
    Champion:
  • 317 Answers
If you don't mind loosing any data on the drive, go to the control panel, and select [Performance and Maintenance] then go to administrative tools, locate the option that says [Computer Management] in the window that pops up, look for the tab that says Disk Management. In the window, find the drive, select it, and hit delete. select yes on the window that pos up. Now right click on the drive which should now have a sub-header that says "Unpartitioned Space" and select format. Leave all of the Default option in the wizard that comes up, and see if this fixes the problem.
Posted on Jan 26, 2008
  • Alexander Selby
    Alexander Selby Jan 26, 2008
    Weird!!!! It seems that for some reason, the computer is not even recognizing the drive, check to see if the proper drivers are installed, otherwise I'm all out of ideas.
  • Alexander Selby
    right click my computer, select properties, go to hardware tab, and select device manager. THen see if there is a yellow (!) next to anything. If there is, go to this link:
    http://www.kingston.com/support/USBFLASH...
    NOTE: make sure to see if your drive is on the discontinued list.
I recently bought my new kingston data traveler (usb) 2gb then i tried to put a few files when i tried to insert it again it was 8 mb only and cannot be fomatted.
> recently bought
Try it in some other computer. If it still has a problem, take it back to where you bought it, and exercise the warranty to get it replaced.
Dec 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hii sir pls help me mine kingstone data traveler 2gb is write protected so how shall i remove write protected?
Copy all the files onto your 'C:' drive.
Spend $9 to buy a new 2GB USB memory-stick.
Copy the files to the new memory-stick.
Take a sledge-hammer to the old memory-stick -- to prevent anybody else from reading your files.
Oct 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a kingston data traveler 2gb DTI. i was copying movie files to my data traveler and it removed the volume label and i am not able to change it back. now I am not able to access any files. it does...
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Feb 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Problem with 32 GB kingston pendrive
i hv a 32 GB kingston pendrive, it can copy any type of data but whenever i copy from pen drive into my pc or copy from my pc to pen drive, it shows multiple empty folders in the same folder n audio-video files got currupted, softwares too. and also unable to delet
May 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I am ignorant. Just bought a2gb data travelor that was completly
Hi lwebber,
The Data Traveler simply stores files. It has nothing to do with editing your Word document. Once you have saved your work on your computer (in the MyDocuments folder for instance) then you can copy the finished file to the Data Traveler. Right click on the file and click Copy then right click on the Data Traveler and click Paste. This process will copy a file to the Data Traveler.
Kingston Tech Support
Apr 21, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a kingston 2gb and i dont know how to get my pics on it
Hi shenicamangr,
From inside My Computer, open the DT then from the menus at the top click on File, New and Folder. Type a name for the folder. Now go an find the picture files you want to copy. Right click on a file to copy (or press Ctrl-A to highlight all files) then select Copy from the menu. Go back to the DT and open it. Right-Click on the new folder you created and select Paste from the menu. All of the files should now be in the new folder.
For more information on how to use the DT go here: http://www.kingston.com/support/howtodt/default.asp
Jan 02, 2009 | Kingston 2GB Secure Digital Memory Card
Wen i copy files or data, few gets copied and the rest doesn't.
Hi rijo_frendz,
Format the USB drive. Then create a folder on it and copy your files into the folder. It should be working now.
Dec 09, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston USB 4GB
sounds like a bad hard disk or a malware virus interceptiong all data and corrupting it.
try www.hdtune.com free home version. if in health tab shows yellow. start looking for a hard disk
try in start, run (type) chkdsk /f black windows shows. press Y then enter reboot. see if it finds corruption. if its data not physical damage, it might fix it!
for virus malware issues i usualy head to majorgeeks.com for top 10 dloads and forum help.
Oct 05, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
