Question about Acer Aspire 5500 5570-2609 Laptop
Computer My computer is not run when i turn it on
  • 270 Answers
Try to run the computer on ac power only by removing the battery . if works may be a paroblem of a damaged battery . if not it may be a hardware fault in system mother board . contact acer suppor t. tell ur problema nd gave it to an acer care ceneter
Posted on Jan 26, 2008
Window updates won't finish running beyond 73 percent. computer message says don't turn computer off.
Turn off the update feature...
If computer is running fine, LEAVE IT ALONE!
You have been forewarned.
Sep 15, 2017 | Beyond Computers & Internet
Computer fan turns on every 2 minutes and runs for 30 sec.
Does your computer seem to be running hot? If not maybe that's all the fan needs to run to do its job. The only thing you could try is to replace the fan.
Jan 04, 2014 | HP Computers & Internet
Computer won't turn on after trying to plug in
You never plug anything into the expansion slot whilr the computer is turned on and running. This is a sure way of damaging the motherboard.
Turn off the computer and remove the wireless adapter and then boot up your computer, if it still does not boot up then the motherboard most likely been damaged.
I suggest you take it to a computer repair shop to assess the damage and give you a repair quote.
Jan 03, 2013 | Computers & Internet
I have no internet to my main computer i rerouted the cable from the router to my lap top then I have enternet but not on my main computer
First, make sure you have the internet cables on your main computer pressed in tightly (to computer and router).
Then carefully follow...
1) Unplug power cord or turn off the "cable modem" (first box that comes into your house provided by the cable company).
2) turn off your router (or unplug).
3) turn off your main computer
4) turn on (or plug in the power cord) for "cable modem" and allow it to run its startup route (1 minute minimum)
5) turn on (or plug in the power cord) for router and allow it to run its start up routine (1 minute minimum)
6) turn on your computer and let it start up and check if internet works.
good luck and rate me please.
May 04, 2011 | Computers & Internet
My laptop won't boot up. When I turn it on the Dell start- flashes then the screen turns black with a blinking cursor on the upper right hand corner.
It sounds to be a hardware issue.. You have to first run a Hardware diagnostics to see if its hardware issue or a software issue.. To Run the hardware turn off the computer.. Keep pressing the F12 key when the computer turns on.. Then select the option diagnostics... If you find any erros on this then you have to replace the hardware parts..
If the test passes then the issue is with the software - reinstall the OS
Dell has a default partition on the computer and you can install with the same..
If you have windows vista on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS in this way..
Dec 05, 2010 | Dell Inspiron 1525 Notebook
My gateway MA1 laptop running win xp has cooling problems
Contact GATEWAY, and get them to fix your laptop.
The fan is designed to run at "full-speed" when you first turn it on, and then there are temperature sensors that slow the fan down, to minimize noise, while the computer is "cool" enough that the fan does not need to run. The sensor is malfunctioning, and is not turning-on (or turning-up) the fan when the computer gets "warm".
Jul 17, 2010 | Gateway Computers & Internet
My computer is freezing up, won't do nothing
Freezing often occurs when your computer is receiving several commands at the same time.
First check your Startup Menu and turn off (uncheck) any programs that don't need to run upon starting up (Go to Start, Run, type in MSCONFIG, select "Start Up" tab and uncheck those needless programs). You can always turn programs on manually when needed (such as media players, games, Instant Messaging, etc.)
Second, check the Options or Preferences in your anti-virus and anti-spyware programs and make certain you don't have a constant scan occuring that will slow down your applications.
Third, turn off any programs or applications that might be running but that you're not using. The fewer programs you have running at one time, the less your computer has to process.
Fourth, when your computer freezes, click on your Control/Alternate/Delete keys at the same time and only once. A window will open called a Windows Task Manager. Select the "Applications" tab if it's not already selected, and highlight any programs which are "Not Running." Then click on "End Task" for those programs only. This way you don't have to restart your computer.
Fifth, notice those programs that seem to cause your computer to freeze and either remove them, replace them or reinstall them.
Dec 27, 2009 | Computers & Internet
Hp pavillion media center a 1540n cpu fan runs, power supply runs, when i hold the switch it won't power-down unless i un-plug video (not even bios) does this mean...
Try clear cmos, if the motherboard bad you must wait so long, maybe you can turn on computer, and they can work perfect, but when you turn off computer on power suply, you can´t again turn on computer.
If this so you have trouble with motherboard.
Oct 30, 2009 | HP Computers & Internet
Computer running on 100% capacity
100% sounds like something bad is running like adware, spyware or a virus possibly.
I would suggest going to Start>Run and type in msconfig. Then go to the startups, and you can uncheck the things you don't need. Things like adobe reader, adobe updates, and such can be turned off.
Second, download and run the following programs, ccleaner, Malware Bytes anti malware, and Super Anti Spyware.
Run the ccleaner and delete all your temp junk, then run scans on both the other programs. You might need to turn off your anti virus program to do this.
Apr 12, 2009 | HP Pavilion a1610n PC Desktop
Computer can't run ,the power is on
Make sure that your monitor is connected properly and turned on.
Jun 21, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
