Question about Jenn-Air JED8430 Electric Cooktop
Electrical hookup My new Jennair cooktop came with only 1 black, 1 red and 1 white wire. Is this 120 volt system. It is a JED8430bds. When I hooked it up the fan worked and the element lights came on but no heat??
  • woodlands55 Jan 26, 2008
    My new cooktop did not come with a bare copper ground. I assume I screw my bare ground wire to the box on the cook top.
    Also, Should I be using a 2 pole breaker for the sub panel.
  • Anonymous Feb 11, 2008
    have new jenn air, it has green, red, white and black wires. the wire coming into the house, now connected to the old cooktop consists of two black wires and a thick twisted wire.
    is this what i need and can i connect them and what exactly goes to what?
    is this something i can do or should i call the jenn air man or electrician
  • 1,314 Answers
No its 220 red to one 110 line blk to the other 110 line white to neutral should be a solid metel wire to take that to ground
Posted on Jan 26, 2008
  • robert samples Jan 26, 2008
    yes 2pole about 30 or 40 amp will do the white wire will hook to the silver metel strips where all the other white wires are
Wiring with 2 wires out of wall
try to use black to black: white to red: and green and white to ground.
you may not have a 240 volt supply to this unit. most of the time when you have these color wires that would tell me that it only has 120 volts of power.
you can try to wire it up as described, but it may not heat enough with just 120 volts.
what type of cook top did you replace, a gas unit and now your changing it to an electric one?
if so, then you will have to replace the wiring inside the wall with the proper size wiring to handle the extra current from an electric unit.
Jan 12, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
I took out an old cooktop which only has the black, white and ground wires. The jennair cooktop with 5 electric elements has black, red, white and ground. how do i connect these together.
sounds like the old one is 110 volts , and the new one is 220 volts. incompatable, as the 220 ones would work, but at half power if you didnt use the red wire. might work fine. omit the red wire and wee what happens
Jun 14, 2009 | Jenn-Air JEC9530 Electric Cooktop
Cooktop WIring
To complying with changed Codes (effective in 2002 ) regarding stoves, ovens and dryers. You will need a 120/240 volt 4 wire 40 amp and 50 amp circuit. This
Decades ago it was permitted to use a 3 wire system (having two 120 volt hots (Black and Red) and 1 combination ground/neutral wire) (green and white) to serve stoves, cooktops, ovens and dryers.
The Code change now requires all stoves and dryers in NEW construction to have the 4 wire set-up (now having two 120 volt hots, 1 white neutral and one green or bare wire ground).
Existing wiring is grand-fathered under the Code change.....I advise you to change the feed wiring over to the the 4 wire set-up...
because - as with ALL Code changes in the will eventually become mandatory for all stoves, ovens and dryers as the grand-father clause drops off. By complying now...
BUT the wiring will need to change to 8/3 with ground. (having 4 wires inside one outer jacket).This is the primary reason for the Code provide a greater margin of safety to the user.
I can NOT recommend the 3 wire hook-up...the 4 wire provides a seperate ground and neutral -
which makes the chance of a user shock when touching the metal frame (from an internal fault in the oven) much less likely then the old 3 wire set-up....
which did NOT have the seperate ground and neutral.
Apr 05, 2008 | Whirlpool 30 in.GJC3055 Electric Cooktop
Jenn air model JED8430bdb
A similar concern on a different model (8230):
To my knowledge, the:
green - ground
white - neutral
black - 120 to ground
red - 120 to ground but between red & black, it should be 240. A Jenn-Air JED8230 requires a 3-wire, 120/240 Volt, 60 Hz Outlet.
Pls consult/confirm with your local electrical utility/codes the availability/applicability of this power/wiring system or reference National Electrical Code, NFPA No. 70
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | Jenn-Air JED8430 Electric Cooktop
Elecrical hook-up for cooktop
Based on your appears the Viking unit may NOT comply with UL and the NEC....but implies that some local Codes may permit the suggested connection...and it may indeed be permitted - if the unit actually draws straight 240 and does not require a neutral for 120 volts (some cooktops do need the neutral for 120 volt control switches...such as your Jennair). Code now requires that new 120/240 units that require the neutral (your Viking unit states that it does not) be a 4 wire assmebly....and your unit MAY be an exception to this requirement.
Under those conditions...then it more then likely CAN be connected as you (and Viking) suggest - black to black, red to red,green to white...and insure that the junction box is indeed well grounded to the supply bare ground wire - so that the metal flex will serve as a supplemental ground to the cook-top.The only other consideration will then be - IS the exisiting wire size and breaker that used to supply the Jennair correct for the new unit..? And if so - then you should be all set with your suggested hook-up...but without electrical nameplate data for both units for comparison...I have no way to determine that....both companies make several different models with different power supply requirements.
If the electrical data is compatible between the two units...then you should be all set as suggested - without having to rewire the cooktop.
Hope this helps...please follow-up if you need more details or have new information for me concerning this cooktop.
Feb 17, 2008 | Jenn-Air JED8430 Electric Cooktop
Wiring installation
You do need a 208/240 volt supply from your service panel. The green is ground, white is nuetral, and the red and black should measure 120 volts each to ground or 240/208 between each other. It is normal for most breaker panels to supply 208/240 between adjacent insulators. If you are only getting 1/2 of that then the circuit breaker may not be straddling the insulator bar but be 1/2 notch out and both breaker pins contacting the same 110 supply.
Apr 14, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
221 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
