Question about Toshiba TW40H80 40" Rear Projection Television
Toshiba TW40H80 diode D7702
Can anyone give me a part number for this diode? Does it have a common replacement; a 1Nxxxx?
  • Toshiba Master
  • 8,617 Answers
Re: Toshiba TW40H80 diode D7702
Diode 7702 is toshiba part # 23118859 its a ultra fast switch 1SS133 it crosses out to NTE-519 If you need anything further let me know.
Posted on Jan 26, 2008
0 characters
3 Points
Hd52w59 Convergence - DL231 replacement
DL231 is a fast recovery diode and should only be replaced with another MUR160 diode.
Mar 01, 2010 | RCA HD52W59 HDTV Projection Television
Toshiba TW40H80 40"
ok! maybe you have defective convergence correction circuit! sir do you have experience in electronic repairing?
Oct 11, 2007 | Toshiba TW40H80 40" Rear Projection...
Dear, I have a Toschiba lcd-TV 42X3000PG. In the power-supply(V28A00036500) their are 2 diodes in short circuit and the main fuse is broken. The 2 diodes are marked with "GA78" ,but i can't find them in...
If it is in Bridge rectifire then replace with 1N4002 Diode and it available in the market.. If in auxilary section better use BA159 ... Replace the fuse with same Amps..
Jul 10, 2009 | Toshiba 50H81 50" Rear Projection...
No picture or sound
You would need the service manual to even begin to troubleshoot a no start situation in a toshiba TV.
Oct 22, 2008 | Toshiba TW40H80 40" Rear Projection...
TV will not turn on
Sounds like a minor problem with the power supply. You can get the manual at this link, and they will provide free tech support to help you diagnose the set. Here is the link if youd like to order the manual and recieve the tech support for free.
Apr 21, 2008 | Toshiba TW40H80 40" Rear Projection...
Toshiba TW40F80 diode D7702
I will check the specs to that set and post an answer if a few moments
Jan 26, 2008 | Toshiba TW40H80 40" Rear Projection...
Sony KDP-51WS655 Need part and info
The cn6001 part number is 1-580-843-11
The Diode part number is 8-719-843-11 (both diodes are the same)
Oct 31, 2007 | Sony Grand WEGA KDP-51WS655 51" Rear...
Toshiba 53AX61/ have sound no picture
I have the same problem with the same Toshiba 53ax61 the picture does not work anyone,
Please email me at
Oct 09, 2007 | Toshiba 53AX61 53" Rear Projection...
Toshiba 42H82 RPTV: Sound but no picture
It sounds like the 200v supply to the crt's is missing. this is the source for driving the tubes, other than the high voltage generated by the flyback transformer. If the set got really bright gray with wome white lines that are kinda on a diagonal, this is generally the cause. the source for this voltage is a diode on the secondary of the flyback transformer.
Jul 11, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba TW40H80 40" Rear Projection Television Logo
196 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
