Memorex MVD4544 VCR will not record
We have out TV hooked up to Road Runner cable, and had recorded some shows into our cable box, planning to save them to a VCR at a later date, because our old VCR had stopped working. So, today I just bought a Memorex MVD4544 VCR-DVD combo. I hooked it up to the cable box via Road Runner cable's instructions, and than copied the recorded shows off the cable box to a black VHS tape in the new VCR.
Two hours later it stopped recording, supposedly done, but when we played back the tape it was completly blank. We retried again with a differant tape, just in case there was a problem with the tape, but once again, nothing was recorded on the second tape either.
Next I figured, maybe there was a problem copying off the cable box, so we tried recording a "live" show off the TV instead. Still nothing.
Finally we hooked it up to a totally differant TV (one without the cable box), and tried recording a show off of that tv instead. Still nothing.
It plays prerecorded tapes beautifully. I checked to see if there was a playback problem, but it plays them fine. It just com[pletely refuses to record anything.
So my question is, has anyone else had this problem? Do you know how to fix it?
Because this is a brand new VCR, should I take it back to the store? If so, should I exchange it for another of the same item, or should I get my money back and buy a differant make/model?
  • EelKat
    EelKat Jan 29, 2008
    I found the problem... I had it hooked up wrong.
    I hooked up the vcr to the tv, but I should have had the vcr hooked up to the cable box instead
  • techno nut Feb 12, 2008
    I hooked the new VCR up to the TV (no cable box) the VCR doesn't record. it does play pre- recorded tapes and tapes I recorded on another older machine but won't record from the TV. The record light is one, SPL can be chosen, and I set it for 30 minutes but when I am done the tape is blank.
    I insert the tape, press record, press AV1 (as it is hooked up to the back). What am I doing wrong?
The problem is this VCR only works if you have cable or satellite, I can not use it with an outside antenna. It will play prerecorded items but will not record. Need a different type of VCR with a tuner.
Posted on Feb 12, 2008
  • 99 Answers
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Posted on Jan 26, 2008
How to hook up vcr when using a cable box
That will depend upon what you want to do. If you plan to record to the VCR from the cable box, then the cable box will need to directly connect to the VCR, then the output of the VCR is connected to the TV. Unfortunately, most VCRs are analog, not digital, so you will lose HD capability (if you have it) trying to connect this way. You also cannot record one show while watching something else (you will need to be tuned to the channel you are recording). If you want to simply use the VCR to view recorded tapes, then connect the cable box to the TV as per the cable company recommendations, and then make a second connection for the VCR. Of course, your TV will need appropriate and available jacks on the rear to do this. It is difficult to give specifics without knowing the models of the cable box, VCR, and TV.
Sep 15, 2015 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
The audio output level is too low. How do i increase it? I have to turn the volume up on the TV almost maximum to hear a "normal" level of volume.
my experience says that the VCR/DVD recorder does NOT has a volume setting inside. Cables may be bad or connected to wrong input but most likely, the TV has a setting for the volume for any source and that is probably set to mid-range like on a PC sound control panel. Go the audio setup on the TV and see if you can adjust the level for each input.
Mar 03, 2014 | Memorex MVD4544 DVD Recorder/VCR
Trying to connect vcr do i connect it to cable box or to back of tv. tv is on the wall thats why I,m asking
If u plan to just to watches video only,than just used a RCA AV component RYW connections hook directly to the LCD tv is find.But if plan to record shows and things to the VCR tapes,than the VCR unit must hook through to the cable box.
Nov 22, 2010 | Televison & Video
Hook up Memorex MVD4544 DVD/VCR combo
ok on the back of the dvd player look for the yellow red and white plugs you should have gotten a cable with yellow white and red plugs match the colors from the dvd player to the colors on the back of the tv labeled VIDEO 1 then plug the power in and tune the tv to video 1
Mar 27, 2009 | Televison & Video
VCR will not record
yes your hook is all correct...but still will not work......unless this is a d-vhs recorder...(and the other way to record hd is dvr)....(note dont throw the standard vcr away) it might and can be use later down road
Jan 15, 2009 | Proscan PSVR73 VHS VCR
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Dvd/vcr without cable hook-up
If ** cable TV hookups exists, then the only inputs you can use are the line-in along with audio left/right. You've probably got a slew of output connections. Your unit does **t contain a tuner (which would allow you to use a cable input). You need to have a cable box or other device (vcr/tv) that has outputs compatible with the input of your dvd/vcr. A lot of dvd/vcrs are that way. It actually saves you some $$ since most cable boxes (especially HDTV compatible) already have the required outputs on them.
Mar 09, 2008 | Memorex MVD4543A
Having problems connecting dvd vcr combo to tv
Hey Pat. Red Yellow White Plugs into back of MVD4544. Red Yellow and white plugs into back of TV. If you have an older TV that has only coax cable outlet, go to Radio Shack or Best Buy and get an RF Modulator. You may need to get another set of Red Yellow White Plugs if you have a cable box. The front connections are Video 2, if placed on the back they are Video 1. When you first turn the DVD/VCR player on, be sure to select the appropriate setting. If you figure out how to timer record on this please let me know. No where in the 52 page book is there any info and their website is a joke. Good Luck.
Sep 14, 2007 | Televison & Video
Televison & Video Logo
201 people viewed this question
Top Televison & Video Experts
