Question about Maytag Neptune Washer
Neptune MAH3000AWW won't shut off automatically
My Maytag Neptune MAH3000AWW washes, rinses and spins fine, but when it reaches the end of its cycle, it won't shut off.  It just sort of rotates every minute or so.  This will go on indefinitely.  If I manually shut it off, the door unlocks after about five minutes, but I would really like to be able to wash a load an not need to be there when it finishes ... or come back in five minutes to dry the load.  I can't imagine that it's good for it to stay on like this.
What might be wrong?
Thanks so much,
 - Scott
  • Scrubz Jan 26, 2008
    Thanks for your response, but I think I need a more specific answer about what part is bad. I'm sure I could fix the problem by replacing the $300 control board, but I'd rather not.
    To your point, there is more than a recall on this model, I understand that there is a class action suite going. I bought it used, so I'm not included.
    The machine is controled by a circuit board and I have alreay replaced what's known as "Q6 600V Triac and R11 Resisitor" on the board to get the door lock to engage and to allow it to spin during the spin cycle. It has worked just fine for a couple of years now.
    Many thanks.
    President:
  • 1,314 Answers
Send me an e mail at b4829@yahoo.com and ill save you some time
Posted on Jan 26, 2008
    Sergeant:
    Champion:
  • 317 Answers
Sound like there is a fault in the control panel. Check the manufacturers website and see if there is a recall on this model. If, not, then take the panel off, and check the selector switch which controls the cycles. See if there is a catch that is not engaging, or not making contact. If this is a digital, board, then you might have to replace the whole entire control panel. Check the instruction booklet on how to order this part. Install should be very easy, just remove a few screws, and swap the parts out.
My maytag neptune mah3000aww spins slowly then reverses, then spins slowly. will not reach regular spinning speed. What is the problem?
it could be a balance problem. Most machines are programmed to abort fast spin if the drum is unbalanced. This can be caused by too much in there, or possible the contents have clumped together somehow. Try a spin cycle only with an empty machine and see if it reaches full spin
Feb 18, 2015 | Maytag Neptune Washer Door Mah3000aww
My maytag neptune MAH3000aww washing won't go into
most common issue with these is the door lock assy. You need to remove the control panel and check the R11 resistor on the board most likely it will be burnt. This was a common issue a few years back. If the R11 resistor is burnt you need to replace the door lock AND control board or your problem will occur again.
Hope this helps _MJ_
Jan 31, 2010 | Maytag Washing Machines
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Maytag neptune mah3000aww spin problem
there are 2 wires going back to the board. They connect to a blue harness. Make sure their is continuity thru the harness. It connects to 3 out of balance swithches. Also check to see if lock light comes on.
Jul 07, 2009 | Maytag Neptune Washer
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag neptune washer MAH3000AWW
order the wax motor kit and replace parts from the internet. there are plenty of videos how to do this. it does require minor soldering and a little mechanical aptittude.
Dec 30, 2008 | Maytag Neptune Washer
MAYTAG NEPTUNE WASHER SHUTS OFF (MAH3000AWW)
motor controller or motor, weigh the cost of the repair before comitting to the repair, new parts only carry a 90 day warranty
this could be a large amount applied to the cost of a new machine
Apr 11, 2008 | Washing Machines
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
re original issue, see if R11 is burned. if so, need to change R11 resistor and associated triac, and probably wax motor so it won't do it again. temporary fix just cut out R11, door won't lock. if your model won't spin that way, depress actuator for microswitch from door wax motor. instructions on web.
Jan 19, 2008 | Maytag Neptune Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
