Question about AEG Lavamat 88840 Front Load Washer
AEG lavamat 6955 showing F9 on display panel
I had left a load in at night with a delay start option and this morning found an error code F9 on the panel. Two spin speed lights and the 'end' button lights are flashing and the load is obviously stuck. Could somebody please help me out urgently with this.
  • 1 more comment
  • richamt Jan 26, 2008
    Thanks for the very quick response but unfortunately, Unplugging the machine did not help. I opened the door manually and took the load out but no matter what I do, the error message F9 stays and I cannot reset it nor restart the machine.
    Still looking for help.
  • richamt Jan 27, 2008
    I managed to reset the machine based on a suggestion that was available on 'askanowner' site.
    http://askanowner.com/qa/view.asp?guid=&...
  • Anonymous Apr 24, 2008
    i have the same problem please discrabie the solution
    Champion:
  • 249 Answers
Unplong machine and restart it .eamonn eire thank you
Posted on Jan 26, 2008
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 11842 Error code E66
http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
Feb 23, 2013 | AEG Washing Machines
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
My wash-machine, AEG oko lavamat 6955, is blinking at the 1500 and 900 buttons, and is showing the code "F9" and the door will not open. How do I fix this? And if I must have a specalist to...
to clear the error code: whilst holding the pre wash and short wash buttons in together turn the control knob from off to gentle spin, this will clear the fault code and run a LED test. (if all goes weel) F9 means carbon brushes need to be replaced
Nov 06, 2017 | AEG Washing Machines
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Lavamat 86800 stop the washing cycle after few seconds without any error code
Hi - did you ever find a solution to the problem? My 12 year machine now showing the same issue.
Oct 11, 2008 | AEG L86800 Front Load Washer
Please help
your machine is draining too slowly. When it initiates a drain cycle, the water level switch is sensing the water level is still too high after 60 seconds so the computer1.gif stops and generates this fault code.
Here are the things to check;
* Check the drain hose and make sure it is not plugged or inked.
* Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
* Check/Clean Drain Pump Filter of foreign objects
* Check for Drain Pump Failure
* Check the Inlet Valve for proper shut off
* Check the Pressure switch for proper operation
Feb 07, 2008 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 88840 Front Load Washer Logo
1,478 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
