Question about Crosley CDE6000 Electric Dryer
Crosley dryer crosley cde7000w installed new motor cycle ran for 50 minutes then stopped without drying clothes, tryed to restart and now will not start? checked door switch and overloads continuity checked out ok?
    Scholar:
  • 196 Answers
Let the machine sit for about an hour and try again. Let me know what happens. Would like to know the reason the motor was replaced.
Posted on Jan 26, 2008
Takes turning on the drying cycle several times in order for the clothes to be dry.Is there a “best” setting to use?
A clothes dryer is as simple as heat and airflow just like a hair dryer. If you have heat then you are probably lacking airflow. Check that the vent is not crushed or pinched behind the dryer and also make sure the main line is not full of lint or anything else that could be blocking airflow. If this is beyond your skill, strength, or aggravation level then you can call a dryer vent cleaning company. Timed dry cycle is the old reliable setting and clothes should be dry between 30 and 50 minutes. The "best" cycle on a dryer is one that utilizes a moisture sensor bar and thermister to determine drying time without over drying the clothes. This will be found on cycles other than timed dry if your dryer has that feature. Always pay attention to the care labels on your clothing as they will tell you how to care for your clothing such as "tumble dry low temperature".
Feb 21, 2018 | Dryers
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Tumble stops cycle when drying. its starts to dry but stops after a short while leaving the clothes still wet,after restarting several times the cothes dry
use multi meter and check moister sensor, cycling and hi limit thermostat lastly if it runs about 25 minutes then stops and need about an hour b4 it will start agin? u have bad motor windings
Nov 08, 2011 | Bosch Axxis WTL 5400 Dryer
Clothes dryer stops spinning before clothes are dry
sounds like a bad cycling thermostat!
May 26, 2009 | Bosch Dryers
Roper REX5634KQ0 runs for two minutes in any cycle and then stops
This problem sounds like a bad motor bearing causing the motor to overheat, when the motor overheats there is a thermal protector that opens and the motor will not run until it cools down.
Jan 06, 2009 | Roper REX4634KQ Electric Dryer
Dryer Problem
EC4 The temperature of air vent
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
You need to call for repairs. Probably the heating element is faulty.
You can create a custom program without a dry cycle and hang dry your clothing.
Nov 21, 2008 | Haier HWD1000
Dryer
dryers take a lot of power to run.the circuit is tripping because it cannot take the load of the dryer.you may have to get a dryer line installed.check the value on the circuit breaker.u need to use twice that value on the dryer.with clothes added to the dryer the motor takes more current to spin.this extra current is greater than the circuit breaker value so it trips to prevent the house wire from going on fire.
Jan 07, 2008 | Kenmore 63942 Dryer
Dyer
Jesse, does the door light come on? If not check the thermal fuse. You will have to open the top by pushing in on the two clips on each side. In back, on the right side of the heater you will see a thermostat and about 4 inches below the thermal fuse. Look at number 5 in the attachment. Makes sure to kill the power before going back there. You can either jump it out or ohm it out to make sure that is the problem. Part number for the fuse is LA1053.. Catriver..post back
Mar 11, 2007 | Crosley CEDC392JQ Electric Portable Dryer
Crosley CDE6000 Electric Dryer Logo
108 people viewed this question
Top Crosley Dryers Experts
Craig Butler
Craig Butler
jasbo
jasbo
Marvin
Marvin
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
