Question about Whirlpool GEW9250 Electric Dryer
Auto feature When I place my dryer on any of the auto features the dryer is suppose to run until the clothes are dry and then turn off. What happens is that the dryer runs until the time gets down to between 8 and 15 minutes. The dryer keeps running, but the timer stays locked on that time. When I finally go check on it, the clothes are completely dry, and the timer still reads the same. The dryer will NEVER shut itself off on an auto mode. please help. thanks,
  • 2 more comments
  • itsabouttime Jan 26, 2008
    Yes, I can run the machine in manual mode. The tech tested the moisture sensor, and said it was ok. This is the second new machine with the same problem.
    This machine is only 1 week old
  • BenandCarri Apr 01, 2008
    I have the EXACT same problem as the one before, how do i fix it?
  • Anonymous Mar 17, 2014
    Timer keeps running but motor shuts off.
    Problem Solver:
  • 3 Answers
If it shuts off too early, it's usually the sensor. If it won't shut off, odds are it's the control curcuit board -- about $150 on line or about $400-500 to have someone coume out and replace it.
Posted on Mar 10, 2008
  • 196 Answers
Faulty selector switch or control card. There is the possibility of a faulty moisture sensor. Can you operate the machine in manual mode ?
Posted on Jan 26, 2008
  • Elmer Vest
    Elmer Vest Jan 26, 2008
    If a tech checked the sensor why did he not check the rest ? In any case the main component for failure is the control card. I believe this machine uses an integrated card. Timer control and control board are one unit.
    How old is this machine ?
Dryer starts fine after a couple of minutes shutts of, I have to restart it several times untill clothes are dry.
most dryers have a sensor that is supposed to shut off auto matic when clothes are dry look at your choises on the dry temperture. one of them usually have automatic whites auto colors etc. the sensor sounds like it went bad. most of them are near the exhaust measures the moisture level to test it remove the wire or wires. then try running the dryer for a little while.
Dec 29, 2011 | Roper Dryers
Wirlpool Estate Gas Dryer that does not dry
i think your temperature sensor is defective in the dryer section..
check it out
May 04, 2008 | Dryers
Maytag dryer epicz says "controls
controls locked
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
To enable the Control Locked feature:
Press and hold AUTO DRY LEVEL for 3 seconds. Control Locked
glows and a single beep tone is heard. To unlock, press and hold
AUTO DRY LEVEL for 3 seconds. The indicator light turns off.
Jul 15, 2011 | Kenmore Elite HE4 Electric Dryer
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
Hi, I have a Maytag dryer, model # mdg308daww Legacy series. It heats up just fine, dries clothes great but the problem I am having is that the Auto dry features are not shutting off as they were before....
you may need to replace the moisture sensor bars inside the dryer.also you may need to check the air flow if timed dry is nnot drying them properly
Dec 19, 2010 | Dryers
Automatic Dry Function Has Stopped Working
There is a humidity sensor which acts as an auto cutoff switch in most driers, as your load auto dries , it senses the change in humidty and kicks the power off. It is often shaped like a flying saucer with wire terminals on the wings. That is likely your culprit, generally located close to the element. Based on your description, I would start there. Also test a load on timed dry, but it sounds like that's your problem. Remember to unplug before looking under the hood. Post back if you need further info
Sep 20, 2009 | Dryers
I have a kenmore 80 series dryer.When using the auto cycle the clothes come out damp
Kenmore Dryers are all almost the same therefore am sending this;
How to Clean a Dryer Vent Video
Why is so inportant to clean the lint?
It was helpful?
May 15, 2009 | Dryers
Frigidaire GLEQ2152ESO Dryer flashing AD
AD means "auto dry", which means the dryer is supposed to be detecting the moisture levels in your clothing and adjusting the drying time accordingly.
If your dryer is flashing "AD" and turning off shortly after the start, there is likely a problem with the mechanism designed to detecting the moisture levels. If it turns off after trying to use all various settings (including the no-heat feature), it is likely a wiring issue.
Mar 27, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Timer does not work in auto mode but does work in timed mode
Check the venting for your dryer. Most "auto dry" features are controlled by a thermostat that is in line with the timer motor. If you have a gas dryer especially, a clogged or obstructed vent will stall the auto dry feature. If you can provide the complete model number, I can provide more insight.
Dec 11, 2008 | Dryers
Frigidaire Dryer Auto Dry Cycle
You may not be giving the auto-dry feature enough run allowance. Set it for more dry and see how it works.
May 27, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
237 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
