Question about Lexmark X4270 All-In-One InkJet Printer
Panel or in All Programs
Comoputer does not recognize the Lexmark X4270. It is not listed in the Control Panel or in All Programs. How can I connect the printer to my new Vista?
    Sniper:
  • 60 Answers
Lexmark tell us that your printer works with Vista:
Operating Systems Supported Microsoft Windows 2000
Microsoft Windows XP
Microsoft Windows XP Professional x64
Microsoft Windows Vista
Microsoft Windows Vista x64
Try reinstall the driver, here is a link where you can download it:
http://www.downloaddelivery.com/srfilecache/cjr4200EN.exe
If all cables are plugged in and the printer is powered up, you should see it in Printers after installing the driver.
Let me know, rate the solution! Thx.
Posted on Feb 01, 2008
Message-P.C cannot communicate with printer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection. If that doesn't help, try the steps below: 1. Disconnect the printer from your computer. 2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. 2. On your computer, go to Control Panel > Printers and Faxes. 3. Delete the Lexmark print object. 4. Reboot your pc. 5. When your pc turns on, reconnect the printer. 6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed. You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file.
Oct 26, 2011 | Lexmark X4270 All-In-One InkJet Printer
I moved my computer from 1 room to another and im having a hard time getting the printer hooked up to my computer
4. Reboot your pc.
Oct 19, 2011 | Lexmark X4270 All-In-One InkJet Printer
My Lexmark z2300 sends to the printer & it says it's printing, but it doesn't actually print. I've tried several file types & programs to print from but none of them work.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
Sep 14, 2011 | Lexmark Z2300 InkJet Printer
My lexmark x4270 can't connect message. what do I do?
4. Reboot your pc.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X4270 All-In-One InkJet Printer
Printer will not print. Removed both print cartrages, replaced black only due to cost/need. Printer will still not print (sheet comes thru blank)
Make sure both color and black cartridges are installed in the printer. The printer requires all cartridges to have ink in them to continue printing.
4. Reboot your pc.
Cant get my lexmark 4270 series going on my computer help
Go to Control Panel -> Printers. Is the printer listed here? Is the printer Online (It will say Online or Offline next to the printer tile)? If it says Offline, the computer cannot currently see the printer so check to make sure it is plugged in and turned on and that the cable is connected from the computer to the printer. If it is Online, right-click on the printer tile and select Properties. On the General tab, click on the Print Test Page button. After a few moments, the printer should spit out a test page. If this prints out, your printer is working properly. If not, let me know what error messages (if any) it displays or the overall printer behavior (blinking lights, beeps or other noises, etc).
Apr 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
I HAVE INSTALLED THE LEXMARK 4200 SERIES PROGRAM ON MY COMPUTER THE LEXMARK IS A X4270 MODEL. BUT I AM UNABLE TO PRINT MATERIAL FROM THE COMPUTER TO THE ALL IN ONE LEXMARK OFFLINE OR ONLINE. IS THERE...
START- CONTROL PANEL-PRINTER AND FAXS.
Is it listed there? If not click on ADD A PRINTER, follow the prompts. if that doesn't work , let me know, and we'll try other things. .
Dec 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Won't print document
i believe this is a usb printer if so if you have turned off the pc you may need to go into the printer and faxes part of the start menu and open it up go to properties and make sure that the printer is set to print online not offline and usb connections can sometimes reset otherwise go to the control panel and see how many times your printer is listed delete all but the one that is listed online and try printing from that one set it as default
best luck
Aug 27, 2008 | Lexmark X4270 All-In-One InkJet Printer
Cant print from new computer
Look in "control panel"(listed in "start") and double click on printers and faxes, if your printer isn't listed, you need to install the disc your printer came with, and may need to goto lexmark.com for driver updates.
Dec 03, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
