Question about RCA P52830BL 52" Rear Projection Television
RCA P52754AT 52 in. No Picture No Sound
Our Projection TV which was left on all night turned itself off and had a smell of burnt wire. When I went to turn it on the green power light would blink for about 3 seconds then stop. No picture or sound. I need to know what the cause could be and is it worth it to repair.
  • 61 Answers
Sounds like the flyback failed,or a loose connt. on the high voltage area of the main board.
Posted on Mar 07, 2008
My RCA 52 blinking power light, no picutre
Flyback transfromer is defective and needs to be replaced.
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
Burnt smell
Beside horizontal transistor a ceramic capacitor .087 2500v (???) burn in the buttom chassis (solder). or fly back start to burn or blown. But I think is a ceramic capacitor.
Apr 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Swirling colors unwatchable screen RCA rear projection 52"
I will assume it does this no matter what the input is, It sounds like the board that controls the projection lamps is causing them to misfire? Or light up out of order in rapid succesion? you will probably need to have the TV serviced, or at least an estimate, so you canfigure out exactly what part has gone bad,( hard to tell sometimes when were not there), but be carefull if you decide to service it yourself.
Apr 12, 2009 | RCA P52926 52" Rear Projection Television
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
No power/button blinks
these tv are easily repaired
if you dont know tv basic,
forget it
Aug 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
168 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
