Question about Samsung TV Remote Control
Samsung Remote code
Samsung technicians have their own code number that they punch in using the remote to view information about the tv. Like lifetime of bulbs, etc. also this is what they use to do adjustments on your screen like the horizontal and vertical screen adjustment. does anyone know this code for samsung tv remote model- bp59-00071b TV model HLR4667W, thanks
  • mhel04 Jan 28, 2008
    I could not read nor extract the file
  • Anonymous May 06, 2008
    remote for HP-S4253 channel up
Hi Friend
My Samsung TV Model is : CS21S67WX/XTML
Serial No is: 0151-32ARC00985Y
I need to use ir remote through my phone so May i know the remote code for this model pls send me a reply at: shakilbasha@gmail.com
Basha
Posted on Mar 14, 2008
  • 1,512 Answers
  • Graeme Ross
    Graeme Ross Jan 28, 2008
    yer, it seems to have a few origins that one. I looked it http://filext.com/file-extension/MDX up when researching your problem. I did find many mdx files for samsung TV service codes however. they all seem to relate to a mx700 remote remote. If you are trying to use on of these, then you will need to use the file i have you to get the access you need with the mx700 to your TV service menu. But i think that you maybe trying to get a standard remote to do these service options. The info i have provided is a patch for a universal remote to get the required functions up.
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
I want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
hi,
Need the model number of the samsung Home home theatre system to give to correct code.
OK
Aug 13, 2011 | Televison & Video
Can this remote work for the tv samsung
I'm glad to inform you that the Universal Remote is compatible with Samsung TV. The codes are 0060, 0702, 0030, 0178 and 0812.
Please click hear to download the manual to view the programming instructions and codes.
Mar 10, 2011 | One For All URC-3021 Remote Control
Couple of questions:  I have a Rear Screen Hitachi 50 something TV that I got from my late uncle, and want to find out the following: How can I tell which model I own? I assume the model number is...
A universal remote will allow you to access all the necessary functions, and depending on the remote that you plan on using, a lot of the time you can use the more advanced functions as well.
If you have the remote working, you can access the model number through the menu settings as well. Get to the generic menu, go to the very bottom of the list where you will see hardware settings or just settings, from there you will see an option that says either hardware information, or information or even just one that says about. If you click on that you can generally find the model number and serial number of the TV.
If you're using a generic "less expensive" universal remote the code for your TV will depend on the exact model number. And you'll have to crawl in behind the TV to get that information then, sometimes you can access the menu from the buttons along the front/side of the TV but not always (impossible to know for sure without knowing the model number of your TV). Sometimes you can fake the remote settings if you punch in the code for any Hitachi TV, guess at how old the TV is and find a number in a code that is about the same size as the TV.
Dec 08, 2009 | Hitachi 57F500 57" Rear Projection...
Code to use with my tv and how to punch it in
the rca systemlink 4 is very good
toshiba code 105,162,160,161,049,072,109.118 one of these should work
press code search
press tv
enter code press on/off
tv will come on
Nov 11, 2008 | RCA Universal Remote Control
Universal SRUSO1011 Remote
Here are the 4-digit codes for my 4 device Philips Universal Remote. It is in pdf format. I have also upload the manual so you can punch forward features, if needed. See the comments at this link. ====>
http://tv.manualsonline.com/ex/thread/view/idThread/549512#comments
Sep 06, 2008 | Philips PM435S Remote Control
Remote control key sequences.
That sounds like something that would be in a service manual. Now that your tv warranty is expired, you can probably buy the service manual off samsungparts.com. I wouldn't have suggested that if your tv was in warranty, because that procedure would be in the service menu, which only Samsung trained technicians have access to when the product is in warranty. Just remember, if you go in the service menu and mess things up and can't fix it, you would probably need service for the tv.
Jan 09, 2008 | Samsung BP59-00016A Remote Control
Codes for a nexxtech tv remote control 3 in 1
Wiki works, folks.
http://kbase.x10.com/wiki/Four_Digit_Universal_Remote_Code_List
All the codes for Nexxtech Universal Remotes, including Panasonic.
Cheers!
Dec 28, 2007 | Sanyo PLC XU35 Multimedia Projector
My SONY TV remote control doesn't do what it should
problem due to dry soldering remote microprocecer
May 21, 2007 | Sony RM-Y135 Remote Control
Samsung TV Remote Control Logo
1,526 people viewed this question
Jerry Greenberg
Jerry Greenberg
