1991 Lexus LS 400 Logo
Posted on Dec 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unlocking 91 Lexus sterio security code
How to unlock 91 lexus ls400 . previous owner put in wrong code to many times and now locked. How do I unlock and what numbers
Anonymous
Level 2:
New Friend:
  • Expert 67 Answers
  • Posted on Dec 24, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
67
Questions
Helped
16545
Points
187
If you don't have the correct code then you need to take it to Lexus and let them do it. It should only be around 50-100 dollars for unlocking and new code...or just buy a new system
2003 Lexus RX300. Door lock relay problem
I have read this 6 times and still not sure what the issue is? I have a 2005 ES330. To open all the doors with the key fob, you have to double press the Unlock Button. Pressing the Unlock button once, only opens the driver door.
The door lock module and further help is in the link.
https://www.google.com/search?q=2003+lexus+rx300.+door+lock+module+location
The Club Lexus forums are a great resource.
RX 300 Power Door Locks problem
ClubLexus https://www.clublexus.com > rx-1st-gen-1999-2003
Jun 24, 2008 - Door lock actuator relay/motor seems likely culprit. It has been discussed in the past. Try the search function. Although a different model, I ...
Power door lock switch do not unlock/lock driver's door.
Aug 1, 2007
03 RX300: Front driver side door lock not working - ClubLexus
Aug 12, 2010
Power door lock relay location? - Lexus Forum Discussion
Nov 6, 2013
RX300 door locks intermittent - Lexus Forum Discussion
Jul 30, 2011
More results from www.clublexus.com
1helpful
Are 91 and 93 Lexus ls400 climate controls interchangeable?
I believe that they are interchangeable up until 1997.
4helpful
My 91 lexus ls400 stopped firing up. It turns over but no go.
check/change the crank sensor and check your ignition module
1helpful
My Lexus LS400 was running perfect - no issues whatsoever. Today it won't start. Have tried jumping it but no luck. It acts like it is about to start but won't.
sounds like an engine immobilizer problem. close all doors,hood & trunk completely. lock and unlock the car three times with remote, then put key in door lock and lock & unlock three times.
did you accidently try to start with wrong key?
1helpful
2answers
My 91 ls400 acts like it vaper locks dies out has to sit awial then actes like it has low power for awial then serges to normal what may be the problem?
this is a computer problem. 91-96 lexus ls400 are known for having their computers go out on them. I would have never believed it but my ls400 did the same thing. I sent the computer to Auto Computer Exchange in Davie FL. They reprogramed it for $310 sent it back to me in a day. It fixed the car. I have had no problems out of the car. I now work on ls400 on the side to fix the same problem for other people.
1helpful
Doors won't lock with remote on my 2002 Lexus GS 300.
are you sure the battery is good in the remote? if so try putting the key in the driver door lock and locking and unlocking the doors three times in a row. if this dosent work i suggest taking it to an experienced lexus shop.
My 1995 Lexus LS400 battery died and now the radio is locked how do I unlock?
YOU WILL NEED THE RADIO CODE.. If you dont have the code you may call the dealer with your vin number, or the radio serial number. it may be in the owners manual, sometimes I write them on the owners manual in case the card gets lost, may look like a credit card.
8helpful
2answers
Radio locked 1991 lexus ls400
do you know how to reset radio code lexus ls 400 /1991
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Lexus Expert? Answer questions, earn points and help others
