Question about Denon AVR-485 Receiver
Center Channel problem!!!
I took it out of storage the other day and now am having a center channel issue. It sounds as if it is scratchy, almost like a cross somewhere. I have changed speakers and wires but no change. It does it thru all feeds to include FM broadcasts. The louder the worst it gets! I really can't justify spending 69 dollars just to be told it would cost 600 to fix! PLEASE HELP!!!
  • 3 more comments
  • LAROUX Jan 26, 2008
    It makes the sound no matter what...Like a pre amp problem or an amp problem...
    Its all hooked up correctly and have swapped speakers out. It will play all channels at once also...Tried to use a different ground as well from another channel just to see if the ground was good.
    yea, tried different speakers and wiring and even took the silly thing apart and wired directly to the board to make sure it wasn't a faulty connection...
    No, it does it at all times, even during a movie...
  • LAROUX Jan 27, 2008
    Yes, its a bad channel do you have a solution?
    Genius:
  • 1,067 Answers
Fm is sterio thats why dont use it in that mode use sterio mode only for movies with voise ok
Posted on Jan 26, 2008
  • 4 more comments
  • nick helpap
    nick helpap Jan 26, 2008
    also lower level on center ch to fade in ith fronts -3 maby
  • nick helpap
    can u try front speaker ojn that ch does it sound ok is it speaker or that bad ch on sterio red on red black on negitive thats all conected right big least 16 gage wire
  • nick helpap
    might be tweeter blown on center then just unplug that one inside it
  • nick helpap
    so center ch out does with on anther speaker bsides that one center u had
  • nick helpap
    ok so it dont matter what speaker u have static on fm only ? when your in fm mode dont use suround sound u can but sounds crappy throew center wehn ther sing sumtims are u in prologic mode when u here it
  • nick helpap
    so its bad ch then on reciver not any speakers corect
No center channel sound on my Yamaha receiver
Is the center channel amp blown? How about checking the center channel input wire for signal?
Jan 06, 2017 | Yamaha Audio Players & Recorders
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
Sound center
Replace center channel speaker with known good one. If no longer scratchy then the voice coil of removed unit is rubbing against the magnet pole and the speaker needs to be replaced. If the replacement speaker also sounds bad, then the amp for the center channel needs repair.
Nov 23, 2013 | Yamaha RX-V490 Receiver
I have a Sony STR-K502P home receiver. While watching a program the other day the center channel stopped working. Prior to that I had recently noticed a clicking noise like a relay switching off and...
It wouldn't be your output transistors. If they go bad they blow the fuse. Sounds like a speaker relay problem. Have you checked the solder connections on the relays? They sometimes break down. If that doesn't help, I would replace the relay. Center channel goes through RY501. Sony p/n: 1-755-170-11.
Apr 21, 2013 | Audio Players & Recorders
Can a power conditioner improve distortion sound on center channel speaker? I have a Pioneer vsx 1020K receiver and I am only having a problem with the center channel. At first I thought the problem was...
First; power conditioner won't do anything for your issue. It's not crosstalk (unless it's a wireless spkr) On your sub are cables mark + & - ? If so make sure they're attached accordingly to back of receiver/amp. Your distortion sounds like a phase issue. I'm also curious how store performed diagnostics?
Mar 07, 2011 | Pioneer VSX1020K Receiver
Onkyo TX-DS696 receiver center channel not working
Can you say explicitly that the Center Channel speaker is defined as something other than NONE?
And how does dialog sound? If it sounds ok you're routing it to the front speakers. This is from the manual...
"For ideal Surround effects, all speakers should be installed. If a
center speaker or subwoofer is not connected, the sound from the unused channel is properly distributed to the connected speakers in order to produce the best Surround sound possible."
Apr 10, 2010 | Audio Players & Recorders
Center channel audio distortion and noise
I have similar problem with my Onkyo Tx-SR600. It only happens when it's in surround mode. When switch to Stereo or Direct, the scratchiness go away. Still trying to find a solution to this problem.
Apr 27, 2009 | Onkyo TX-SR606 Receiver
Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Jan 28, 2009 | Pioneer VSX-D608 Receiver
Center channel
Back to basic to advance:
Be sure you have all speakers connected correctly behind the receiver.If you center channel don't have any sound,it could be 7 different issues,but you could try to just hook up your center channel to either the right or the left speaker output to be sure the center channel speaker does work.
Check your the speaker wiring tip(if there is any),i will use just the speaker wire go straight to the center speaker output,go to the receiver to change it to pro-logic or dolby digital and of course you should put in a dvd in the dvd player to have a good quality movie to play the dialogue through the center channel for you test.
If you have tried the above step and still have no sound,you might consider hiring a troubleshooting master to take care of your issue.
Let me know what you need!
solutiondoct
Nov 05, 2008 | Pioneer VSX-455 Receiver
Center channel turns scratchy.
Sorry to inform you, The driver transistors or IC is going bad, or there might be a poor solder connection on the center channel Amp. If you know how to solder, you may be able to poke around at the center channel amp circuit, with a wooden or plastic tool, and maybe see where the bad connection(s) are. To get a shop to looki at this unit, may not pay, but that is all up to you, on how much you paid for the unit, and how much your willing to pay to get it fixed. Read this great article and see if it helps you to decide. http://www.techlore.com/article/10602/How-to-Determine-if-you-Should-Repair-a-Broken-Device/ Good Luck Please do not forget to rate this thread.
Dec 17, 2006 | KLH R5100 Receiver
Denon AVR-485 Receiver Logo
105 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
