Question about ViewSonic G790 19" CRT Monitor
Screen problems i turned my computer on and its jumping.just a little though.it just started doing it a couple of hours ago
    Novelist:
  • 123 Answers
Check TRC heater voltage (6,3 V., pins 3-4 of TRC socket counting counterclockwise) when picture goes off; if there's no voltage but it appears when picture comes back, look for bad solder joints tracing the circuit backwards to the power supply. Usually, the 6,3 V. tension comes from a single diode-electrolitic cap circuit at the secondary of the power supply transformer.or check this
Pin assignment for a monochrome 9-pin D connector are:
1, 2: Ground
3, 4, 5: not connected
6: intensity control (contrast)
7: video signal input
8: horizontal sync.
9: vertical sync.
Video monochrome cards usable are:MDA (monochrome display adapter) HGA (Hercules graphics adapter) -Some CGA (Color graphics adapter) and EGA (enhanced graphics adapter) cards that have a switch mono-color can also be used.
Posted on Jan 26, 2008
I have a 98 dakota it will start and only run for a few seconds then shut off. None of the guages are working either. It will crank and run sometimes (I had it running for about two hours a couple of days...
take the cluster out of dash-pull the plugs apart and re-plug a couple times,also do this with the main cpu-the connections can also corrode-and could be cleaned up-a tool to do this can be bought at an auto parts store-looks like a bunch of skinny files-
cheers Denny
Nov 19, 2013 | Cars & Trucks
Maytag mod. #med5700tq0 elec. dryer runs, inconsistent heat, high heat two days ago, little heat a few hours ago, some heat an hour ago, no heat now. Where is the best place to start?
It sounds clogged up to me. Take the exhaust hose off the wall and try it first. Another thing that happens with Maytags is that the motor shaft will **** out the center of the plastic blower and even though the motor is turning, little or no air is moving through the machine, so the high limit thermo turns the heat off
Oct 18, 2011 | Maytag MED5700TQ Electric Dryer
My '92 Trooper just started shut off and won't start. i had to clutch start it. It crank vigorously but wont Start . A few wks ago. I stated it and shut it off as I had to do something before I go and it...
i would start by having the starter checked, if you can jump start with the clutch then this tells me its a starter problem,have that starter checked,
Mar 03, 2010 | 1992 Isuzu Trooper
Polaris 2006 fusion 700 - Intermittent starting
I think on a worn startermotor.
To be sure, give a little knock on the startermotor end when it won't start. If then it's good starter, then its the startermotor.
If still not good, replace your battery.
Mar 30, 2017 | Winter Sports
Jumpy color changing screen with slow speed. Please HELP!
When booting your computer press (F8) And go to "Safe Mode" then when you are on your acount go to: Start>Run>type "msconfig" then go to "startup" And disable All then click apply and close then restart. Hope this helps you.
May 16, 2008 | Toshiba Satellite M45-S169 Notebook
Problem when turning monitor off
mcdevito75 here LCD, or liquid Crystal display, chances are the crackling is the inside liquid display trying to capture the in comming electricity to make a display picture. Remember even an LCD is nothing more than a light bulb, a very intricate light bulb but a light bulb, and you have light bulbs burn out when you put them on and almost never as the are on burning. Turning the monitor itself off won"t really save electricity or the monitor itself as, when you shut down the computer from Start (left side of screen) the monitors screen saver comes on for 10--20 minutes then goes off, at this point the electricity is at the monitors on/off switch and not going thru the monitor at all. If you turn the monitor off at it"s on/off switch, the sudden jump of electricity to the monitor from it"s on/off switch could hurt it, or even the switch. I have a friend who turns off the monitor also and that friend had a bad monitor in 3 years. I never turn my monitor off just the computer itself. I'd speak with a Radio Shack, Staples, Best Buy ETC. for more advise. Me I;d say leave the monitor on. Hope this helps.
Mar 27, 2007 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Problem with display
It sounds Heat related. As the monitor heats up, it begins going crazy. Maybe unplug and blow out with compressed air.
Hope this gives you some ideas.
Oct 04, 2017 | Samsung SyncMaster 1701MP (Silver) 17 in....
ViewSonic G790 19" CRT Monitor Logo
96 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
