Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Disassembly GE JEM21K 003 microwave not heating. There appears to be one hidden fastener (RH side) that I need to remove for disassembly. Help?
  • n_frank Jan 26, 2008
    Disregard - it was not a fastener, just a tight fit. A well-placed tap with a mallet did the trick !
  • GE Master
  • 9,176 Answers
Very good.
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
If you still need troubleshooting help. feel free to reply back top this discussion.
Posted on Feb 09, 2008
6ya staff
SOURCE:
What does F4 mean for the GE Micro JEM31
"F4" on a GE is normally a defective humidity sensor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
See these files for disassembly help:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 20, 2011 | GE JEM31 Microwave Oven
Have a GE Profile Microwave Oven Model JE1540. the door switch has worn. How do you replace the door switch? Thanks
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Jan 17, 2011 | GE Profile Spacemaker JVM1871 Microwave...
Have a GE Profile Microwave/Convection oven. Microwave works, but the convection part does not. Has been this way since installation. Oven will go through preheat cycle, say that oven is preheated but it...
It may be a bad convection heating element or just a bad thermal cutout.
If it's less than one year old, it will be fully covered under warranty and you can contract GE here to have an authorized servicer come out and fix it free.
If it's out of warranty and you or someone you know wants to check it out, I'd first suggest you take a look at the "mini-manual" hidden inside the unit (behind the control panel, hidden on the left side behind the grille, or attached to the inside of the outer cover) which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Otherwise, see these files: safety disassembly
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 25, 2009 | GE JE1540 Microwave Oven
GE MICROWAVE JMW 1630
That would be either a shorted top door switch or possibly a shorted main relay on the control board.
Either is a pretty simple fix.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag here.
If you only need a switch, you can order a universal type here for $5 postpaid.
Here are some other helpful files in case you need them:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Feb 08, 2009 | GE JVM1630 Microwave Oven
Microwave runs but does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 17, 2008 | GE JVM1440 Microwave Oven
Microwave heats bowl but not food
First of all, you must be sure you are using a microwave safe container. If it is not marked as such, it is not.
Try heating a cup of water in a clear glass container. If it still does not work right, your stirrer may be bad.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
LIGHT BULB
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Nov 25, 2008 | GE JVM3660 Microwave Oven
Similar Problem
Yes of course. The latch system is designed to keep it from cooking with the door open.
If the latch is broken, it will not activate the door switch, which is used to tell the oven it is closed.
We have critical safety & disassembly info (including a how-to video) at our site, linked here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Please write back with your brand and model number if you need further help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 15, 2008 | GE Advantium SCA2001BSS Microwave Oven
No turntable, no heat. Light, vent fan and keypad all work...
That would be a problem with your primary interlock switch or its mount.
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The interlocks are highlighted in the diagram below.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 28, 2008 | GE XL1800 1100 Watts Microwave Oven
Not heating at all all of a sudden
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
May 24, 2008 | GE JVM1440 Microwave Oven
Disassembly of GE JVM1460 microwave oven door to clean
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Mar 10, 2008 | GE JVM1440 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
319 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
