Question about Slant Fin Cool Mist GF-220 Humidifier
Installation of mineral pads
Very bad instruction manual. mineral pads seem to go beneath nozzle but nozzle appears to be permanently fixed. how to remove nozzle so i can install mineral pad beneath it?
  • 3 Answers
The nozzle is NOT fixed in place. Force it either clockwise or counterclockwise (it doesn't matter. Then simply lift up. Deposits may have accumulated leaving the impression that it cant be moved, but it can!
Posted on Feb 09, 2008
6ya staff
SOURCE:
Unclog personal humidifier doesn't work
If this is an ultrasonic humidifier, in the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 25, 2015 | Humidifiers
How do I prevent white dust from coming out of my humidifier
They make Mineral Absorption Pads that will soak up the minerals in your water. Alternately, buy distilled water from your grocery store. They sell it in 2.5 gallon containers for about $2.
Feb 23, 2015 | Humidifiers
Slant fin doesnt turn on
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Jun 23, 2014 | Slant Fin Humidifiers
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
Jun 22, 2017 | Aprilaire 600 Humidifier
Rinsed my humidifier with water and wiped the base down, refilled it and now it seems to be making the mist in the base butbisnt making it's way out of the mouth of the dolphin
The tubing to the mouth of the dolphin or the misting nozzle is clogged with mineral buildup and scale.
To clean this, do the following.
Empty the water in the tank and replace it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Allow the unit to sit for 30 minutes, then turn it ON. If mist does not appear within 10 minutes from the mouth of the dolphin. Turn the unit OFF and allow it to soak over night. In the morning, turn the unit ON and allow it to run. Once the mist appears where it should, run the unit until the tank is half empty. Then empty the tank of the remaining solution and refill with Bottled Distilled Water and run the unit until it is empty. This will flush all the remaining solution from the tank, tubing & nozzle.
In the future I would recommend using Bottled Distilled Water on a regular basis, rather than tap water. Doing so, will eliminate the problem of scaling.
Hope this helped you and thanks for choosing FixYa.
Sep 07, 2011 | NewAir AU-200E Humidifier
Why does it discharge a white powder in the mist?
  • Sorry to read about your problem, I hope this helps you out.
  • you could say you have dirty water. Unplug the humidifier from the wall.
  • 2 Remove the existing water from the humidifier. Water contains several types of minerals, including iron and sodium, which cause the white powder when released into the air.
  • 3 Clean the humidifier according to the manufacturer's instructions. This may involve disassembling the unit and replacing the humidifier's filter.
  • 4 Pour demineralized or distilled water into the humidifier's tank. These liquids have a lower mineral content than tap water.
  • 5 Consider switching to a humidifier that comes equipped with a demineralizing filter, which removes the minerals found in tap water before they are dispersed into the air.
  • I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
    4 Thumbs - Very Helpful
    3 Thumbs - Helpful
    Dec 31, 2010 | Air-O-Swiss U7142 Humidifier
    My Clairion SD1015 just stopped working. It's been working fine for 1 1/2 years.
    the process this unit uses to evaporate water (boil water) leaves behind any minerals from the water . this builds up on the heating element and requires regular cleaning .. you can soak it in white vinegar to help remove the scale .. here is a URL that gives specific instructions on how to do that ...
    http://www.clairion.com/usermanuals/DD_SD_eng.pdf
    if there is enough buildup, the heating element gets too hot ... it may trip a thermal fuse .. if this happens then its likely that the machine will appear to have no power at all ... the thermal fuse is located inside the machine and is soldered or crimped in .. it requires a person with technical expertise to change that .. the heating elements go bad but not often ..if your unit lights up but simply doesnt give vapor output then it may be overheating inside due to buildup on the heater ... it might take a couple of days to get all that cleaned off the heater ... there are two sensors that detect that the machine is assembled correctly .. if its not then it will refuse to operate ... also one of the sensors could be bad ..
    Aug 18, 2009 | Clarion Humidifiers
    How do you change the mineral absorption pad?
    The pad is very easy to replace. Simply remove the water tank. The mineral pad floats in the hot water reservoir. Pull out the old one and discard if it has begun to break down. That's all their is to it.
    I hope this helps.
    Jan 01, 2009 | Slant Fin GF-210W 2 Gallon Humidifier
    Cleaning instructions
    nvm :)
    Features: Low Maintenance:
    * Regulated Release ™ System - eliminates stagnant water while preventing mineral build-up on the wick or filter, which can impede performance in ordinary evaporative humidifiers.
    * Dishwasher-Safe, Easy-Clean Base and Tank - with antimicrobial agents molded into plastic parts to inhibit the growth of microorganisms.
    * PermaWick ™ - permanent wick never needs to be replaced, saving up to $45 per year in replacement filter costs.
    * Top Down Water Dispersion - evenly disperses water from the top over the entire wick to prevent mineral build up that can impede performance.
    May 22, 2008 | Hunter CareFree Plus 33222 Humidifier
    Humidifier blows out dust
    As the previous poster said, it's probably a problem with your water.
    Are you using tap water or bottled mineral water? If so, there are minerals which get nebulized along with the water, and leaves a white, dusty, residue. I fill my Crane Pig humidifier with DISTILLED water, which is pretty pure. Make sure that the water is DISTILLED ONLY, since some of the water companies distill the water and then add minerals back in (they almost got me here until I noticed the label that said "with minerals added"). The reason this is important is because during the distilling process, the water is boiled, evaporated, and then the vapor is condensed back to liquid. This removes any impurities or dissolved minerals from the water. You can see Wikipedia for more on this topic here.
    Additionally, I use both the Crane Demineralization Filter Cartridge (which works for the penguin as well, and gets installed in place of the original water tank cap), and the ProTec PC-1 Humidifier Tank Cleaning Cartridge (which I plop into the water tank) to keep the water both de-mineralized and bacteria free. I got both products at Amazon.com.
    With these 3 things, so far I haven't had any white dust residue, and the mist feels fresh and clean.
    On a side note, by using distilled water, you also prevent any mineralization from building up on the nebulizer or water level sensor, which can cause the humidifier to eventually stop producing mist...
    Nov 19, 2007 | Crane Penguin 1 Gallon Humidifier
    Slant Fin Cool Mist GF-220 Humidifier Logo
    260 people viewed this question
    Top Slant Fin Humidifiers Experts
    Marvin
    Marvin
    Rich Brown
    James Gettemy
    Are you a Slant Fin Humidifier Expert? Answer questions, earn points and help others
