Question about Acer AL1716 17" LCD Monitor
AL 1716 LCD monitor has no power when plugged in.
Hello everyone i have a Acer 17 inch monitor that when plugged shows no power what so ever. The typical green light for power does not even show nor do the switches to turn it on work. I have completely taking apart the monitor to see if i could at least find a bad resistor or capacitor. I would appreciate any advice as to where should i start making judgment if the main 450v capacitor is receiving power tested by a mulitmeter?
  • 2 more comments
  • fannta1 Feb 16, 2008
    I have the same problem,does anybody figure out what's the solution?
  • dodge1063 Feb 22, 2008
    Hey guys i appreciate the input on what needs to be looked at. I have looked for the regulator ic and some of the capacitors, I have posted some pictures of the circuit board. I would appreciate and info as to pin point which regulator ic,
    Fuses which are F101, 2 black fuses near CN101 i should look at...
    http://home.comcast.net/~dodge1063/1.jpg
    http://home.comcast.net/~dodge1063/3.jpg
    http://home.comcast.net/~dodge1063/4.jpg
    http://home.comcast.net/~dodge1063/5.jpg
    http://home.comcast.net/~dodge1063/6.jpg
  • juno69 Dec 22, 2008
    Hi dodge1063's, I have the same problem with my screen , could you send me photos of the IC regulator
  • drilonkojcin Dec 25, 2008
    where do you get the 25 volt caps
As someone suggested the 3 10 volt 1000uF caps are bad. You can indentify them because they're puffed up on the top and therefore blown. Replace them withj a 25 volt cap 470uF or larger and away you go. I did 4 of them in 3 hours. The case snaps apart which is the hardest part. them remove all the screws you can find, unplug the display from the board, remove the rest of the screws holding the power supply board down, and look for the puffy caps. Cahnge them and put everything back together and away you go.
Richard
Posted on Jul 21, 2008
Hey I made a home voltage tester.Take light bulb 120V and connect with two wires.i put ends to the place as shown on picture and the LED light started working!but nothing else :(
picture 1
picture 2
picture 3
picture 4
Posted on Feb 22, 2008
  • 75 Answers
Try replace the regulator ic
Posted on Jan 27, 2008
  • Marc Cuyag Feb 22, 2008
    thi is the image u senthttp://home.comcast.net/~dodge1063/4.jpg
    the regulator ic is 3pin transistor typ package that top a heatsink.
    that is a regulator ic.
    befor u raplace it can u get a voltage test in a big capacitor how much volts he drain..
It's a switching power supply ! Make sure all 3 fuses are OK then if you see caps are swollen, that means caps are weak, leak or defectiv. Try to change all caps then regulator IC.
Fuses are F101, 2 black fuses near CN101.
I suggest to replace C123 because it's a feedback caps.
Posted on Feb 21, 2008
Lg LG M1717S lcd moniter no power , what is broblems and solution please,
thanks
Posted on Feb 15, 2008
Acer AL1711 17" LCD Monitor showing white screen
A white screen indicates the power supply board is not putting out the correct voltages to properly power the monitor, just the back light. This type of issue is caused by a failure of the filter capacitors on the power board. You can rebuild your power supply board and bring the monitor back to life by just replacing the the bad capacitors. The problem is that model the Acer AL1711 could come with 1 of 4 different power supply boards install depending and the date manufacturer and supply on hand. If you want to repair the monitor if you could open the unit and get either the model number of the power supply board or send a picture of the board to me I will be glad to help you repair the unit and get it back up and running. You can contact me to send the information at tech@ccl-la.com
Nov 30, 2012 | Acer AL1711 17" LCD Monitor
Monitor model 1702FP wont start. lights keep cycling
The flashing power and signal lights are caused by 4 bad capacitors on the main driver board. Here is a link to information showing where they are and how to replace them.
http://www.instructables.com/id/FREE-17%22-LCD-Monitor---How-to-do-it%3F/
Sep 23, 2012 | Dell 1702FP 17" 1280x1024 .264mm Midnight...
Envision en-7500 won't power on
The problem is in the power supply board, at least one capacitor is open, sometimes will bulge at the top making it easier to spot.
Jun 10, 2012 | MPC Computers Envision EN 7500 17" Flat...
My view sonic VA712 monitor doesn't display any picture even after power supply light shows green.
Hello Dear I also have the same problem and finaly I found its power adopter faulty which gives the same voltage as mentioned above it but on load they dropped to 17 volts instead 19. I used another supply and the monitor works normaly.so try this
Dec 19, 2010 | ViewSonic VA712 17" LCD Monitor
Hello i have a acer lcd model AL 1715 SM it doesn t have a vga input and cable is damaged how do i chenge it
Apr 07, 2010 | Acer AL1715 17" LCD Monitor
My Acer Al1715 monitor does not display a picture the power is fine as the green light flashes but no picture at all
The light should come on steady. Your monitor most likely has the typical failed capacitor problem. The Power Supply board in the monitor most likely has some capacitors that have failed, visible signs include swelling of the ends of the parts, but they can fail without showing any visible sgns. Replacement of the capacitors often restores operation.
Feb 02, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
I have a AL 1716 monitor and the on/off button is
More likely to be bad caps with bulginh tops in the power supply, common problems, see some example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 06, 2010 | Acer AL1716B 17" LCD Monitor
Acer monitor only display for about 3 to 4 second
Sounds like a busted syncing circuit, probably due to a condenser. It takes about that time to heat or overcharge, at which point a safety feature will turn off the display.
You just MIGHT get some more life hours out of the monitor by tuning it to a lower resolution, but it will buy you a month even in the best hypothesis.
I'm afraid the monitor is in for a repair/replacement.
Oct 30, 2009 | Acer AL1716 F Monitor
Acer AL1716 17" LCD Monitor Logo
1,173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
