Question about Frigidaire GLTF2940ES Front Load Washer
Water filling tub on washer
I have a Frigidaire Gallery series front loader washer. Two times this week, the tub has had water in it; it's clean water, and the water has definately drained at the end of the prior cycle. What should I check? If the intake valves need replacing, is this an easy fix? Help!
    Scholar:
  • 196 Answers
First thing is to run the machine as normal. After the cycle is complete and the clothes are removed, turn the water off, hot and cold, to the machine. If on the next usage there is no water in the tub then the fault has been found. And, no, the water valves are fairly easy to access and replace if needed.
Posted on Jan 26, 2008
Water continues to leak from water outlet into tub
-Tight more. If no solve the problem then replace with new seal.
Good luck
Mai
Jan 18, 2018 | Washing Machines
Frigidaire gallery top load washer
After 13 appliance years, your washer is a candidate for replacement.
Aug 08, 2017 | Frigidaire CWS3600AS Top Load Washer
My whole house smells like rotten eggs when I run my washer. I have read it could be the lint trap. Where is the lint trap on the Frigidaire gallery front loader?
. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out
Aug 15, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire gallery series front loader washer model gltf2940e it keeps giving error e10 what do i do
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Sep 15, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire gallery series front load washer that flashes an E10 error code. What is this for.
E10 = long fill.
Check hoses, faucet and water valve screens first. Clean if necessary. If this did not help - something has failed in the washer, either the pressure switch, control board, or water valve.
Apr 10, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Error messages
what are other codes? i believe this could be a cold water issue. check your screens at the fill hoses
Sep 22, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigadaire front loader washer
Water not reaching the dispenser is one of the codes.
does it fill with water.
is it on a pedestal is the drain hose below the washer?
is it getting hot and cold water.
if water is not entering ,open the top and check the wiring to the water valves (where the hoses screw on)
Feb 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
E10 error with NEW front loader fridgidaire
Are you sure that water fills the tub ? Close the hot water tap and check if cold water fills in, then close the cold water tap and open the hot water one and check whether hot water fills in. Let me knw with your test results.
Aug 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
127 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
