Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher paykel DD 603 SS double dish drawers
I took doors off because motor controller panel needed to be replaced after being damaged from power outage. The dishwasher was working after part was replaced but then it started leaking in the middle of the cycle the 1 st time I tried to use it. I then tried the bottom drawer and it was leaking also. The doors had been removed from both units but they had been put back on and seemed to be on properly.
  • sully356 Jun 02, 2008
    My DD-603SS top drawer quits mid cycle. I would like to fix but have not service manual. Do you know where I can purchase the manual?
  • Anonymous Mar 14, 2014
    I have a paskal and fisher double dishwasher DD 603.. One drawer will not complete a cycle. No matter which "time" you choose it pauses multiple times. As it gets closer to finishing the times gets shorter and shorter in between having to hit the start/pause button
  • 770 Answers
Post your email i will send you the manual on the breakdown of the unit
Posted on Jan 27, 2008
3 Suggested Answers
  • 5 Answers
SOURCE: fisher and paykel DD-603 dish drawer
Hi there, If you have had an F1 you need to dry out the product in order to reset the flood switch. This is a simple process as follows: 1. Ensure product is disconnect from wall so that it has no power. 2. Open the bottom drawer and put your hand in through the gap where the bottom of the bottom drawer comes out and feel the base of the cabinet that houses the drawers for water. 3. If there is water present dry it out as much as you can with paper towels or old rags. This machine is designed to drain all water to the front of the base of the cabinet away from the flood switch that sits at the back left corner of the cabinet base that the drawers are fitted into. 4. When you have base of the cabinet dry you need to ensure that the switch has not moisture on it in order for it to reset and allow you to start using the product. This can be done 2 ways: 1. leave bottom drawer open for 24-48 hours to allow natural air circulation to dry out the connection. or 2. position a hair dryer to blow air into the back left corner of the base of the cabinet and dry it out quicker. This still make take up to 6 hours as the flood switch had a protective cover over it to try to prevent F1's for small spills. 5. When the product had been dried out, important that you make sure it has, when you switch on the machine the F1 should be gone and ready to use. Please run each drawer seperately on a rinse cycle to confirm to yourself that it flooding was possibly caused by something blocking the sprayarm, or something stacked too high or something got stuck in the pump temporarily stopping it from draining effectively or the product suddsing too much from spilt rinse aide in one of the drawers. If each drawer runs successfully you should be in the all clear to start using it again. Please note though: if something blocks the spray arm that is directly linked to the pump your drawer will flood as a result. If you have something stuck in the pump peventing it from draining effectively ie a toothpick or piece of broken crockery this will cause your product to flood, but you will hear an louder than normal sound when the pump is running. And finally if you spill rinse aide in your drawer when filling it clean all spilt rinse aide to prevent unit from over sudsing when running. Regards KAR-Ltd
Posted on Aug 09, 2007
SOURCE: FISHER & PAYKEL DD-603
I HAVE A DD603. Thr F1 comes on about every 2 weeks. I shut power off & let it dry & it works fine for acouple of more weeks. Any idea why this is a on going problem and how to fix it?
Posted on Nov 06, 2008
Dishdrawer f2 error
This is linked to a rotor problem. Check this video and clean the cavity. If no difference then need to replace the rotor.
http://www.appliancerepairlesson.com/2011/02/25/fisher-and-paykel-dishwasher-dish-drawer-repair/
Feb 16, 2014 | Fisher and Paykel 23 in. DD-603 Built-in...
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
My single Fisher & Paykel dishwasher drawer DS603I (Integrated Panel) turns on by itself even after turning off the light switch that controls both units that sit on opposite sides of the sink. The...
Yes ,you may be able to restore function by completely drying the area and PC board located under drawer.Use a hair dryer.
However , you will still have a leak and the problem will return.Usually the leak is drawer lid not closing properly. Suspect lid actuators have failed.Very common.Or some kind of obstruction.The drawer can be removed easily by removing 2 large plastic scews at drawer front.If lid actuators have never been replaced go ahead and do that.It is normal for other drawer to work fine.
Hope this helps you
Aug 16, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
I have a DD603 Double drawer Fisher and Paykel dishwasher, it is leaving a residue on the dishes. I currently have Jet Dry in the rinse aid reservoir. What is causing the dishes not to get clean?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 29, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Flood switch activated, intermittent beeping, motor will not turn off
Please confirm if it is a single or a double drawer.
How do you know the flood switch is activated? Do you have a display on your dishwasher and what is it showing? If no display then which lights if any on the panel are on?
Motor will not run if flood switch is activated in the fisher paykel drawer dishwwasher.
Nov 20, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I have a dish drawer DD603 purchased in 2005. It
I presume you have a double drawer model.
Does this problem occur with both drawers?
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
No power to top drawer so I cant even run a
If the controller is faulty then you will not see any life in the drawer unit. The controller is mounted on the front of the unit behind the door panel.
Oct 19, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & paykel double dish drwer
The code is a water leak problem.That is the warning
May 15, 2008 | Fisher and Paykel 23 in. DD603H SS...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
455 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
