Question about Minolta X-700 35mm SLR Camera
My camera wont work right
Hi
so i got this camera from a lady on ebay
then i put new batterys in it and every thing work
but the shutter, and the film wined
what should i do
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    Does the meter light up? If so, what happens to the meter display when the release button is fully depressed?
  • 36 Answers
Did you mean the shutter wouldn't open and close?
if yes, this is common to most cameras idled for years. the shutter curtain or leaves stuck, or the electronic unit that powers the shutter mulfunction.
eBay sellers are not always honest. return it if you are lucky or file a complaint. let me tell you about my experience there. i bought a used Yashica, but when it arrived, some parts went wrong enenthough i specifically asked, the condition was not as stated, and lens cap seen on pic was not included. the seller was a kind of rude manner, he just refused to admit though eBay suspended him from trading.
Posted on Jan 26, 2008
This Yashica FR's film advance is loose and does not wind the film, the shutter button does not work either! It has a new battery in it. Any help would be greatly appreciated. I'm not sure if I'm miss
yashika is a really cheaply built brand of camera, they always have been. as cheap as they have gotten now you might as well come up to the digital age. but if you are one of those hard core old school photographers then you can find some good canon, nikon or pentax film cameras on ebay really cheap. i wouldn't mess with this one any more
Feb 22, 2013 | Cameras
The film wont roll out as i take pictures
Are you sure the film is attached to the take-up spool ?
Sep 13, 2017 | Pentax K1000 35mm SLR Camera
My Pentax SPII shoots blank images
You can check the shutter without film in the camera. Remove the lens and open the film door. You will see the cloth curtains of the shutter in the center. Advance the film lever to **** the shutter and set the speed dial to a slower speed like 1/15. Hold the camera so it is aimed a a light source, (a window will do) and fire the shutter. You should see the light through the shutter for the time duration is is set to. (1/15). If you see the light source, repeat the process going up one speed setting until you reach 1/1000. If you see the shutter open and close as described, then try another roll. After you load the film and close the back door, make note of what the rewind knob is doing as you advance the film. It should spin counter-clockwise each time. That is a easy test to know that the film is traveling in the camera properly. Vary your exposures with the new roll at different speeds and f-stops. You should get exposures, but if not let us know.
Jan 31, 2010 | Olympus Stylus 850SW Digital Camera
My shutter wont fire? I have new batterys good film and everything it just wont work the light meeter works though?
If you can wind the film there is a problem with the shutter release. Take it to the shop to be checked and/or repaired. There's practically nothing you can do yourself (unless you're a camera mechanic).
Nov 17, 2009 | Pentax ME Super 35mm SLR Camera
Film winder jammed halfway throgh a film and i took that film out ( it expired anyway) and i tired to put new one in but i couldnt becuase the film winder wont move do i have to get this repaired?
Check all the batteries. Get fresh ones. If this is a manual, lever-action film advance and you have a camera with a spring-driven shutter you probably have a stripped sprocket and it needs new parts. If you have an electric shutter but there's one spring driven shutter speed as a backup, try that setting. If it is a totally motor driven advance, try checking the drive battery and clean the contacts. If the motor drive is removeable, take it off and try the lever-action advance. Remember, a group of AA cells are only as good as the weakest one. Good luck
Oct 29, 2009 | Photography
Film wont advance
Metering lights are the LEDs that light up in the viewfinder. Camera on, look in the viewfinder to the right side you will see some lights. As long as these lights come on, P, M, A, *, ^ ,- You have put the batteries in correctly, and they have juice. Otherwise, you got the wrong batteries or put them in backwards.
The Minolta X-series (X-300/370, X-570, X-700) were known for this issue. Two capacitors under the top and bottom covers go bad over time. They prevent the shutter from releasing, so you cannot wind to re-**** the shutter. If you're handy at these things, you can buy the caps, remove the covers, solder in the new caps, and be fine. This issue is well known and you can find instructions on the web. Or you can send it in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at $58 incl return postage. Look him up on the web.
Sep 29, 2009 | Minolta X-700 35mm SLR Camera
Minolta 35mm X-370 stuck shutter
You are probably on the right track with the batteries. Stick some fresh ones in and the shutter should release. Your may need to use the advance lever to re-**** the shutter and drop the mirror down. You could also try removing the lens and manually pushing the mirror down to see if it stays in the down position.
Mar 16, 2009 | Minolta X-370S 35mm SLR Camera
Minolta X-300s film loading problem
Hi -- yes if you cannot advance the transport mechanism ( and so cannot load the film ) this is because shutter is not working ! This a very common problem and is due to leaking capacitor ( 220 microF ) situated on the botttom of the camera. Remove bottom cover and replace the capacitor . You should be able now to release shutter and load your film.
Aug 20, 2008 | Photography
MInolta x-300s film camera - shutter will not work
Remove bottom cover ( 4 screws ) and find small shutter release capacitor ( 6 v 220 microF ) and replace it. These older capacitors start leaking after 8 years and have to be replaced. Make sure you get the polarity and specs right when you are putting a new one in.
Sep 01, 2007 | Photography
Minolta X-700 35mm SLR Camera Logo
140 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
