Question about Dryers
Dryer not heating up
I have a Whirlpool Imperial Series dryer model #LEN200PWO. It is not heating up. I've checked the outlet for voltage and it' s 240. I've checked continuity on the element and temp switches and anything else I could get my meter on in the back of the dryer. Any suggestions.
  • 1 more comment
  • vanhde Jan 26, 2008
    I found the problem. The heating element was open. I pulled it out and found a break in the wire. Thanks for your thoughts.
  • Anonymous Feb 18, 2008
    Where is the heating element found and what does it look like?
  • dixonkm Nov 13, 2008
    I have a Whirlpool Imperial Series dryer model #LEN200PWO. It is not heating up. Only had it for a litter over two years. You would think something new would last more than two years. Is this a problem with Whirlpool drier? I had an old Maytag that lasted for over twenty years. Buy something new it may last a years. What's wrong?
    President:
  • 1,314 Answers
Did you un hook 1 side of the wire from each componted you were checking to prevent getting a false reading and did you check the thermal limiter on the heater housing the tiny disc with two wires on it and do you have the tech sheet for the dryer
Posted on Jan 26, 2008
Whirlpool Imperial gas dryer won't heat up.
There are two thermal cutoffs. If you pop open the top of the dryer and find the heating element the bigger one is mounted directly on top of it and the other one is located below it. Those are the thing to check first. You can test with a multimeter set to test continuity. If those are bad that means that the exhaust vent is getting clogged. Those run about 34 bucks for the set. The other piece to check is the element itself. You can test that the same way. Those run between 50 and 70 bucks. Good luck.
Jun 28, 2012 | Whirlpool Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
I have a whirpool dryer that is not heating model number wed5550sq0 Imperial series. I took the heater coil off. is that the only thing it could be?
On the heater element housing is 2 limits.
If either of these are open the dryer will not heat but it will run.
More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 18, 2011 | Whirlpool Dryers
My Whirlpool dryer LGT7848AQO imperial series does not heat up. HelP!
Check the fuse/circuit breaker box, you need 220/240V to heat the dryer. If there is proper voltage going to the dryer, then you will need to goe inside and check the limiters and element.
Feb 17, 2010 | Dryers
Whirlpool imperial series dryer heats not spinning
This problem is almost always a broken belt. Yes you can do it yourself.
Go to repairclinic. com and put in your model number for the exploded view of your dryer. Locate the belt part number and belt orientation.
Jan 03, 2010 | Whirlpool Dryers
Whirlpool Imperial gas dryer won't spin
It's a broken belt. Replace the tensioner assy also
Nov 03, 2009 | Whirlpool Dryers
My Whirlpool Imperial Series Dryer is 4 years old. NO Heat.
Sure there is. The cheapest I have found is on amazon. click here Dryer Heating Element 279838 For Whirlpool Kenmore and take a look. I hope this was helpful. cheers
Sep 07, 2009 | Dryers
Dryer will not heat
Model number needed to look up fuse location or simply use Repairclinic.com to look up the fuse location yourself. These newer models have not been out long enough for a retired old dude like me to come across one. But I bet I could repair it.Since yours is this new you might want to get factory service to take a gander at it before you attempt a DIY to prevent voiding any warranty you may have left.
Jan 10, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryers Logo
184 people viewed this question
Top Dryers Experts
Marvin
Marvin
