Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell Ultrasharp 2005fpw
Hello dear friends,my problem is pretty simple.when i open up my screen,it stays white with a black bar growing and decreasing in size intermitently.could you help me out by your first guess on what would be the problem??
thanks
Jack
    Novelist:
  • 123 Answers
The problem you are describing is definitely a bad picture tube.please replace it or the problem you are describing sounds like high voltage regulation problems. The easiest way to tell is by changing from a black raster to a white raster. If the size changes quite noticeably or jumps alot then you have a regulation problem. The first thing to do is check your high voltage while changing the raster from black to white. If the HV varies by a large margin, then you have a flyback problem. If it doesn't, check the voltage at the collector of the HOT while varying the raster again. If the voltage changes alot then check your B+ line. Typically what goes out in this case is a capacitor(typically 100uf-350v or so) or the B+ regulator. Hope this helps.
Posted on Jan 26, 2008
Dell 2005FPW screen turns black after a second ,can not get it back on
this is a fairly common problem. The backlight circuit is probably shot. Not much to do but replace the monitor.
Oct 05, 2014 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell UltraSharp 2005FPW shut down wont power up.
You can have the board repaired for $50 or you can inspect it first for bad connectionc, bad caps, etc.
http://www.lcdrepair.us/2005fpw-power.html
Apr 22, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell 2005fpw flash problem
Often this is a capacitor problem, there have been many problems with them as of late. http://www.badcaps.net/forum post here and they will be able to help you out.
Jun 12, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell screen
Hi...there,
It's open from the front bezel of the screen. But if you are still under warranty...send it back to Dell for repaired... Happy Holidays!
Dec 05, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Opening Up a Dell 2005FPW
Hi...there,
If you got power with no screen or both... Then it's your backlight inverter are busted. Need to replaced or repaired. To repaired look for a capacitors with a bulged on top of each caps. Not sure...just replaced all the caps... Good lucks!
Oct 07, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
No display.
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Make sure the proper input is selected
1: D-SUB for Blue VGA cable
2: DVI-D for White DVI cable
The option selected should be indicated on the power save screen.
If changing the input select and rebooting the computer have no effect an no video from the computer is ever displayed, then the monitor is in need of repair.
Jun 30, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Screen resolution
1680 x 1050 at 60 Hz is the ooptimal resolution and the only one that will not be fuzzy.
http://support.dell.com/support/edocs/monitors/2005FPW/En/about.htm#Specifioications
press command - shift - a to bring up the Applications folder. Then open System Preferences. Click on Displays, from there you should be able to adjust the resolution
Oct 10, 2006 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
120 people viewed this question
Alun Cox
