Question about Mitsubishi VS-45605 50" Rear Projection Television
1992 mitsubishi vs-50va2
Vertical problems picture wont stay still, it just keeps running vertically. is there an adjustment or what needs to be replaced
  • Mitsubishi Master
  • 8,617 Answers
This symptom is typical of the infamous PIP module with the leaky
electrolytics. If the corrosion has not become so bad that the board is
unrepairable, you can change all of the surface mount caps and clean up the corrosion
Posted on Jan 26, 2008
Mitsubishi vs 55601 picture has gone out. It was
I have found several of the vertical deflection caps to be off value as well as the vertical chip to be defective.First after pulling the chassis (mark plugs and sockets that have no id numbers with a mark a lot) look with magnifier around vertical and hi section for circuit board cracks that need resoldered.Hope this helps.
Technition
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Big Screen Projection receiver TV vertical pincushion problem
the aliment is out need a profession to adjust it for you
Jul 24, 2009 | Televison & Video
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Vertical picture problems on my 1993 mitsubishi vs-50va2
Can you provide a more detailed description of the vertical problem you are seeing? There are a number of defective parts that can cause different symptoms. Few vertical problems are adjustments. Most are either poor solder connections or defective parts. The parts cost should be minimal.
Please confirm you model number here and try to provide more details on the problem.
Thanks,
Dan
May 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
I have lines like vertical hold is off but can't find ajustment
Thank you to "TheScreenGuy". He replied with an answer that says the vertical sync is automatic and that I need to replace the SSB. Thanks!!!
Mar 23, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi model #VS-4543
2 THINGS CAUSES THIS PROBLEM ON THESE --- THE BLUE PICTURE TUBE HAS LEAKED FLUID ON THE CIRCUIT BOARDS ,,,THAT 'S BAD
AND SOMETIMES ,WHEN THE VERTICAL CIRCUIT GOES OFF ,,THE SCREEN WON'T LIGHT UP ,,,THAT NORMAL ,,,KEEPS FROM DAMANGING OTHER PARTS
U NEED A TECH TUNICA
Oct 29, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Mar 04, 2007 | Mitsubishi WS-55807 TV
Mitsubishi VS-45605 50" Rear Projection Television Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
