I have a Sylvania model LD320ss8 combo tv with power problem
Right out from box this tv never works. I know that there is power because the stanby light is red. When I press the on/off button on tv and remote as wel, the light turns green and blinks 2 times per second after few secons the light blinks faster then turns back to red.
Ihope you can help me. has been 6 months since a bought it. the 800 numbers from sylvania denied their help.
thenks in advance if you can respond to this matter.
regards
Dino
  • Anonymous Apr 18, 2009
    I just bought mine and it blinks green 2 times and then nothing. The screen does not come on. Can anyone help me?
SOURCE: Service menu codes
We had a problem on our flat tv 21 inches with model 21fx4al, when we press the power button to turn it on the red light flashes in more or less 3 seconds but no display at all. Please send us an immediate solution.
We are waiting for your feedback. Thank you.
Leinor Mojica
Posted on Apr 20, 2008
  • 10 Answers
SOURCE: i have a sylvania LD320SS8 32" digital/analog lcd tv witha built in dvd player
I can rebuild the invertor boards in that model to fix the shutting off problem. The boards themselves are on eternal backorder. Email me at aplusrepairs@triad.rr.com for more information.
Posted on Sep 29, 2008
djchillsnyc
  • 152 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
  • 3 Answers
SOURCE: akai lct3201 power problem
I fixed my Akai LCT3201AD in about 30mins. using 3 small parts from Radio Shack. Once I got the back off, I found the power supply board (PSB), mine was part# MLT-169B rev1.2. I looked at the capacitors (caps.) first, because they are usually easy to diagnose. I noticed the caps. bubbled out on the top of the board (where all the cables connect to it). There is 3 of them in a row, positioned between the two large heatsinks. My guess is that the heatsinks are generating a LOT of heat over time, because of bad ventilation, and causing the caps. to fail.
I went to Radio Shack and found 3 caps. (only had 3 in stock). The original ones were 16V-1000uF, Radio Shack only carried 35V and 50V in the 1000uF caps., so I bought the 35V ones and headed home, I removed the old caps. from the board, and installed the new ones. The 35V caps, are a little bigger, so its a tighter fit on the board, be careful. It took longer to remove the back from the TV than it did to do the soldering. YouTube.com has excellent videos on how to de-solder caps. on PSB's.
Total money spent on repairs:
$1.59 ea for 3 Caps. (part# 272-1032) $4.77
$2.99 for new soldering iron tip + $2.99
$1.00 donation for St. Jude's + $1.00
Total including tax $9.30
So for less than $10, I did a repair that my local TV repair shop wanted $575 for. Online stores want anywhere from $100-$275 for a PSB. If I get another 2 yrs out of it that's well worth $10.
Posted on Dec 16, 2008
  • 54 Answers
SOURCE: Sylvania LD320SS8 HDTV Can not program COMCAST Remote Control.
try the various codes listed for phillips. that should cure your problem. if not try sampo.
Posted on Jan 22, 2009
My Sylvania lcd tv/DVD combination model LD320SS8 A keeps shutting off as soon as you turn it on
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 28, 2015 | Sylvania Televison & Video
What is the onn universal code for sylvania model 6719DFDF
0392. Check this code. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 10, 2015 | Sylvania Televison & Video
Remote code What code to program Universal control
0092,0099,0091. are the codes to check. If you wish to get more codes and other details check:
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 12, 2014 | One For All Televison & Video
Cant program dish network remote to my sylvania tv/dvd combo
Not likely will your current remote ever have the capability for your newer model. The code sets are designed into the Dish remote as they were available then and don't 'learn' newer sets.
You might try to find one of the other Funai brand code sets under these names:
Funai, Symphonic, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
Even if you do find one that gives you some functions, I doubt you will find one set for both TV and DVD player so you will have to try individual code sets; one for TV, another for DVD.
Jul 12, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
In my Sylvania LD320SS8 A the picture is beeing cut off, the TV channel ID and half of the close capture letters are cut off, I have change the screen setting to full, cinema, and all others with the same...
If you have a cable box attached to the tv, check the "aspect ratio" on the cable box. there should be a button on the remote for the cable box. this may solve your issue.
Apr 17, 2009 | Sylvania LC320SS8 32 in. LCD Television
Jan 21, 2009 | Sylvania LC320SS8 32 in. LCD Television
Desconectar
Decime el modelo de tu televisor tiene que ser un numero como este
Sylvania SST4324S 32"
Sylvania SST4324A 32"
Sylvania SST4324 32"
Sylvania SST4323 32"
Sylvania SST4322 32"
Sylvania SRT2432S 32"
Sylvania SRT2432P 32"
Sylvania SRT2323 23"
Sylvania SRT2232X 32"
Sylvania SRT2232S 32"
Sylvania RSET432E 32"
Sylvania RSDCT3203 32"
Sylvania LD320SS8 32"
Sylvania LC320SS8 32"
Sylvania C6432TE 32"
Sylvania C6432TD 32"
Sylvania 6632LG 32"
Sylvania 6632LCT 32"
Sylvania 6432TFY 32"
Sylvania 6432TF 32"
Sylvania 6432TE 32"
Sylvania 6432TD 32"
Sylvania 6432GG 32"
Sylvania 6432FE 32"
Oct 19, 2008 | Air Tools & Compressors
I have a sylvania LD320SS8 32" digital/analog lcd tv witha built in dvd player
Take the Inverter Board out and check for Open windings on the 6 Transformers along the edge of the board. When you find one open, get the number off of the Transformer, Google it, buy one and replace the bad transformer. I was given one of these TV's and fixed it for $11. It's not rocket science, if you can use a DMM and a soldering Iron, you can fix this.
May 22, 2008 | Sylvania LC370SL8 37 in. LCD Television
Programing one for all remote for a sysvnia model tv ld320ss8
I also own a Sylvania LD320SS8 HDTV. My solution to the
problem of remote codes that won't work is to junk the
Sylvania, and buy a reputable brand TV such as an LG
HDTV which will work nicely with DirecTV or Dish network
remotes.
Feb 28, 2008 | Televison & Video
Power
did you see the stadby light? or if you have not stanby light you have defective power supply!
Oct 22, 2007 | Sylvania SRC22134 13 in. TV/VCR Combo
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
