Question about Acer Aspire 1640Z Notebook
Monitor My monitor will go fuzzy and lock up, then go blank. If I move the monitor it may or may not resolve the problem temporarily. I am assuming there is a connection problem, but have no clue on how I can fix it.
    Problem Solver:
  • 12 Answers
Try tapping the keyboard when it does it, the connector is under the keyboard, if that works then the keyboard end o the connector is loose, i it changes when touching the screen the connector at that end could be loose, have you dropped it?
Posted on Jan 26, 2008
The right hand 1/3 of the screen is blank. Cannot get anything to display
sounds like you have to set the monitor resolution using your computer. right click desktop... graphics options. or Properties. look for Resolution slider. Move it around. press apply. see what happens. if it now fits but is fuzzy. change the refresh rate eg. 60 Hz or 75 Hz. On the monitor itself there is typically a button that allows you to move the image to fit the screen, quite often these settings are inadvertently played with by children ect. look for buttons/ menu's on your monitor itself. play with the settings .
Aug 24, 2010 | E-Machines eMachines Monitor E15T4
Out of the blue, the icons on my desktop are fuzzy/wavy. One day fine, the next fuzzy/wavy. I hooked up another monitor and got the same result. Any suggestions!
I'm assuming that you have tested the other monitor by using another cable so in that case the video card on your pc is dying, replace it.
Jul 07, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Monitor is fuzzy. A bit like double vision
Try moving cables around, may be too close to, another, power source. Plugs may be loose tighten.
Apr 30, 2010 | Acer AL1716 F Monitor
Monitor went to time out when i moved mouse it came back fuzzy i rebooted and now all it does is launch, still fuzzy, but goes out immediately
Hope you are not using a Wireless mouse. If so change to a normal mouse. Click Start button - settings - Control panel - power management option.
Restore to the default settings by selecting from the dropdown list on the powe schemes tab - laptop\desktop and carefully look at the power management options. Please check for virus on your system with a good antivirus software. This should resolve the issue else you have to do a OS Repair. Good Luck.
Mar 14, 2010 | E-Machines T6212 PC Desktop
I have a dell monitor that the power light is on but yet the screen is blank? Changed both vga cable & power with no effect?
Pls check that the your system is working or hang on the blank screen .For system check pls press the Num lock button on your keyboard its on/off or not.If your keyboard Num lock button is on/off then Problem with your Monitor might be might be EHT is faulty its better call vendor for repair.If system hanged on blank screen then problem with your RAM OR Hard disk or Operating system.
For Hard disk pls remove the power cable from Hard disk and on the system if not resolve then
Go for RAM,remove the RAM chip and re-installed another goods RAM ano on the system, If still blank screen then Problem with Operating System .Get it re-installed Operating system
Nov 16, 2009 | Dell E173FP 17" LCD Monitor
Monitor goes fuzzy and then blank
Contact HP at 1-800-HP-INVENT
-=/ Daft Tech /=-
Oct 22, 2009 | HP Computers & Internet
Monitor screen goes blank
Check the chord of your monitor connected AC Supply.
Mar 16, 2009 | Toshiba Tekbright 15" CRT Monitor
Images and letters are fuzzy on my Westinghouse Monitor
Your monitor settings are not correct or you have a bad monitor cable. Wide screen settings are sometimes hard to figure when you have a wide screen Westinghouse mntr. You have tried all common resolutions? 1024 x 768, 1280 x 800, 1280 x 720? I assume your video drivers are the latest?You have tried all common resolutions? 1024 x 768, 1280 x 800, 1280 x 720? I assume your video drivers are the latest? That monitor is a **** btw! take it back to Best Buy. No other store sells them that I know of.
Jan 15, 2009 | Computers & Internet
Monitor lcd acer al2016w 20" letters and image are fuzzy,,why?
I also have an Asrock motherboard (M266A) and have the AL2216W. The image and text is also fuzzy. I did improve it a by by unplugging/replugging all of the connectors on the back of the computer. I believe my mouse had a somewhat loose connection and this was causing interference. I can actually create interference on screen by moving my mouse up and down.
These Acer monitors seem to be very sensitive. I also tried this monitor on a old Desktop with Win98 and another new laptop with XP and it looks good on those computers, but not on my Asrock based system.
Nov 30, 2008 | Acer AL2016W 20" LCD Monitor
Fuzzy picture and in a different language
click on "menu".
then move to the "hand" while clicking on lightview
then clivk select/auto
it should automatically select the third from above
then move to the top while clicking on lightview
and now change the language with the "sun" buttons
Dec 17, 2007 | LG Flatron L1715S 17" LCD Monitor
Acer Aspire 1640Z Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
